Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
I have an eureka power plus vacuum floor cleaner and i have no way of opening the botton to the brush to change my belt for the brush since the brush will not turn.
  • 430 Answers
Look for two screws at the edge of the brush housing. You may see these ones on top. They will be black and recessed
Posted on Sep 07, 2009
Eureka Optima 431x Belt replacement
Not sure if this is any good but here is a link to a youtube video showing how to remove the cover and change the brush and belt.
https://www.youtube.com/watch?v=JxoHDvr1ZJI
Apr 07, 2013 | Eureka 431A Optima Bagless Upright Vacuum
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
CHANDE BELT
you can find out how to change the belt in the manual here that I included on page 4.
http://www.eureka.com/servlet/FindOwnersGuide
Good Luck And Please Rate FixYa!
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Mar 08, 2008 | Vacuums
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
246 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
