I have a panasonic digital cordless phone (KX-TG5839) and my 4yr old daughter set a dial lock password and we don't know what it is - can we override it somehow?
SOURCE: How to disable dial lock without password
For the KX-TGA181AL
The "small inverted triangle" flashing in the bottom left hand corner of the screen indicates that -
the handset is too far from the base.
The AC adaptor is not connected
High electrical inteference
The handset registration is canceled
I presume that all is well with the base which leaves the handset registration. to reregister.
Press the OK button.
Press the down button (Setting HS should now be displayed)
press OK
Press the down button untill REGISTRATION is displayed
Press OK
on the base unit press and hold the ittle button on the left side of the base unit for about 5 sec.
On the handset press up or down to select a base unit number.
Wait untill BS PIN is displayed
Enter the Base unit Pin no. defalut is 0000
A confirmation tone will sound and the triangle should have stopped flashing.
that should sort it out,
BTW to lock and unlock the handset press and hold the OK button for 2 secs
SOURCE: panasonic KX-TGA236JXS gigarange phone is dial lock
panasonic KX-TGA236JXS give error dial lock
SOURCE: Dial Lock Password
hello friend i know what is your problem with your mobial.if that password is not working your phone is affected with virus.you want to format it.then you put a new password.then it will be ok.
may god bless you my friend.
SOURCE: Dial locked in panasonic KX-TGA351BX cordless phone. How to open
I've got KX-TGA351BX phone. It was in use for 2 years but due to relocation it was out of use for almost a month. One fine day I tried to re-install it and found ''Dial Lock''. Unable to make outgoing calls but can receive incoming calls. Can anyone let me know how to open the lock (I forgot the old password)?
SOURCE: PANASONIC KX-TG2340JX TROUBLESHOOTING
my small dghutor turn the dial lock on by mistake .we trry to turn it off but we couldn't coz we don't know the password No. so plz hellp us the Model No KX-TG2340JX Panasonic
