Question about LG Vu CU920 Cellular Phone
Charging Circuit in my LG NV2 doesn't work
The wall adaptor works on another phone, and so does my battery. The battery simply will not charge in my LG NV2. Is there an external charger available because we find out now that all the downloads are licensed only to this phone - if I get another phone, I have to buy all the downloads again - this was burried deep in Verizon's fine print. So anyway, how can I charge my battery?
  • 21 Answers
You may caused physical damage by forcing the charger in which may have caused the pins on the curcuit board to break. by the way if you had warranty on the phone, you just lost it because to repair this lg would suggest you should buy a new phone, and they also charge for inspection, i reccomend you dont waste your money sending to them, look around on ebay for a charging unit for just the battery im sure you will find one.
here is one link which i found, you just simply connect it to your computer with usb, put your battery in there and it charges
http://www.blueunplugged.com/p.aspx?p=136150
please rate if this fixes your solution.
Posted on Sep 14, 2009
My acer aspire one D260 wont charge,the wall adaptor is in but not charging
  • Turn the computer off
  • Unplug the computer
  • Remove the battery
  • Plug in the power cord
  • Power on the computer
If it powers up, you have a battery problem; It is either the battery or the charging circuit. Replacing the battery is easy and not too expensive. Fixing the charging circuit on a laptop is not economical.
Hope this helps. I do this for fun & 4 thumb feedback, not $$$
Jim
Oct 05, 2011 | Acer Computers & Internet
3110 showing charging but not save in battery
Check the battery on another phone and see if there is charging , if not the battery can be defective. Also checking the adaptor voltage and the voltage on the terminals in the phone will confirm if the charging circuit is working . If so replace the battery after confirming with a similar type. replace only with the original from Nokia.- with warranty .
Sep 03, 2011 | Nokia 3110 Cellular Phone
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Plugged in not charging on Dell Inspiron 1525
your answer to your problem lies here.
http://www.howtomendit.com/answers.php?id=141277
If you have the battery at a low level and it's not charging then i think i might have worked out what might be the problem:
First flash the BIOS to Revision A17 (or later if available)
Then power off and turn on the laptop with AC adaptor plugged in, hit F2 to go into BIOS and go to Battery Info.
If you can see 'AC Adapter 65w' at the bottom then there shouldn't be anything wrong with your power supply or the laptop. If it says 'Unknown' then there's a problem with your motherboard or the AC adapter.
Feb 12, 2010 | Dell Inspiron 1525 Laptop
Battery is working fine but laptop is unable to charge the battery
If the battery is definatly not faulty, and the laptop won't charge it, then I would assume the charging circuit is faulty. As they are built in to the motherboard that would need replacing.
Nov 21, 2009 | HP Pavilion dv1000 Notebook
My LG phone isnt charging, what problems could there be?
please check this firstand try to put on other mobile unit that is compatible.
1. charger
2. battery
if it still not working probably the problem is in hardware of your device and that is what we call "not charging"
the last option that we can do is to get you unit to a mobile technician and ask then to check the charging device of the unit.
thanks
Feb 19, 2009 | LG OEM VX8500 Series Vehicle Charger ,...
Phone Won't Restart After Charging
This seems that you battery is faulty. just get a new battery and your problem will be solve.
Jan 03, 2009 | LG KU990 Viewty
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
LG Vu CU920 Cellular Phone Logo
381 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
