Question about Garden
Trying to remove the axle off of a 1995 john deere tractor lawn mower. is there a pin holding the axle holding each side inplace?
  • Anonymous Mar 14, 2014
    pulling pivot pin in front axle of 2005 case ih jx95 tractor
  • 115 Answers
Pop the rubber cover off there should be an e-clip under this that can be popped out with a small flat blade screwdriver.
Posted on Sep 05, 2009
How to I remove the steering wheel from SX75 John Deere riding lawn mower
I have not been able to pin down your exact model but this link is to another model that may give you the info you need. john deere 214 steering wheel removal
Oct 17, 2016 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
What is the torque on the front axle nut on a John Deere 3215b fairway mower
You should consult a John Deere mechanic then but a repair manual for your equipment.
Sep 20, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Unable to remove rear wheel of my jon deere rx75 lawn mower
they rust on after a while i just change the flat tire on the mower leaving the wheel alone sounds had but not a hard as it sounds
Sep 18, 2012 | John Deere Garden
Remove front tire on lawn mower
Jill,
If the tire has a hole have you considered a Plug?
If thats not an option before you can pull the tire off, there should be a small snap ring holding it in place. please use blocks to block the tires and do the following.
  • Park the lawn mower on a level surface, then place the wheel chocks in front and behind the rear tires.
  • 2Place the jack under the frame at the front of the mower. Raise the mower up and place the jack stands under each side of the frame. Lower the jack until the mower frame sits firmly on the jack stands
  • 3Remove the plastic cap in the center of the wheel by hand; this should expose the snap ring holding the wheel to the axle.
  • 4Pry the snap ring off the axle with the flathead screwdriver. Slide off the washer, wheel and the shim washers from the axle.
    To replace tire follow steps 3 and 4 in reverse order. place shim washers back on and then wheel and then snap ring, etc...
    hope this helps
  • May 29, 2012 | John Deere Garden
    Change rear tire on john deere lawn tractor lt-150
    i guess the wheels are stuck you will damage the wheels and axle trying to get them off just pop the beads and change it right on the mower
    Apr 16, 2012 | John Deere Garden
    Steering, The right front axle and tire lean in as if I were turning the steering wheel in the left direction but the left axle and tire remain straight. If I turn sharp to the left the right tire turns...
    1) there are also bushings which hold the axle assembly into the front cross member, take a look at those.
    2) while you are at it, replace the front wheel bearings on both sides
    Aug 07, 2011 | John Deere Garden
    I have a 21 year old john deere 175 hydro lawn tractor with a 38 inch deck and it needs a new motor and a new swith to engage the lawn mower deck how much is it worth with those being broke ?
    Trans 150$.Mower deck 50$.Hood 50$.Fender deck and seat 75$.Front axle and spindles 75$.Electric clutch 40$.This is what you can expect to get if you part it out or you can trade it in for 250$ on a new Deere.
    Mar 21, 2010 | Peg Perego John Deere Turf Tractor
    How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
    1993: 010001
    1994: 020001
    1995: 030001
    1996: 040001
    1997: 050001
    1998: 060001
    1999: 070001
    2000: 080001
    2001: 090001
    http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
    Mar 10, 2010 | Garden
    Can't get front wheel off my john deere lawn tractor
    remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
    Aug 22, 2009 | Garden
    Garden Logo
    43 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
