Question about Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Describe your Kenmore 24032 24036 Top Load Washer Problem
F1 is displayed when starting, what is, and how do you clear it???
    President:
  • 1,776 Answers
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
The above is from a service bulletin. I have also seen this problem caused by a loose electrical connection between the flowmeter and the control board. Try unplugging and reseating the plugs between them and look for any signs of corrosion and clean if any is found. Sorry for the trouble you are having and I hope this helped. Best wishes.
Posted on Sep 05, 2009
Testimonial: "thank you"
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
    F1 (F60-68)
    Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
    See Accessing & Removing the Electronic Assemblies.
    F1 flashing on the display indicates a primary control failure.
    "F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
    The link below lists Cabrio failre codes.
    http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
    Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My kenmore oasis shows the f1 upon starting the machine and at 23 minutes and often shows th ul why is this
    Mine is doing the same exact thing. Just after I press "Start", the F1 starts beeping. Then at 23 minutes into the cycle, it does it again. So frustrating! What is wrong with this machine?
    May 20, 2010 | Kenmore Oasis HE 27082 Top Load Washer
    F1 code coming up on my Oasis HE washer
    YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
    Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
    MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
    Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
    That is a bad water valve. Try my washer PICTORIAL for directions on replacing that water valve. NOTE: this is a pictorial of how to replace your drive coupling but you need to bust this ****** loose to get to that valve.
    Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
    Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
    Hopefully this will stop the washer from shaking.
    Vic
    Jun 30, 2009 | Kenmore 24032\24036 Top Load Washer
    Water pump is my first guess. Did you check the hoses that hook to it? The pump is in the front of unit. Give full model number to further assist you.
    Jun 15, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
