Question about Garden
My Stihl chainsaw starts up but then it won't stay running. Changed spark plugs and tried new gas, but didn't fix the problem.
  • 116 Answers
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
Posted on Sep 05, 2009
    Problem Solver:
  • 10 Answers
Check the diaphram in the carb
it souds like its gettin fuel but not enough also make sure the airfilter is clean,it may not be gettin enough air and cause it to flood
Posted on Mar 02, 2011
3 Suggested Answers
SOURCE: have stihl O25 chainsaw, starts, runs about 5
hey have the same o25 stihl,great saw when their working right.have had to replace fuel line to carb 5x over 7yrs.hairline crrack and it will **** air and conk out in 2-5 seconds.also there is a pulse line to carb which can also crack.if you have good spark at plug its likely a fuel delivery problem. collin
Posted on Jan 15, 2011
  • 82 Answers
SOURCE: where is the spark plug located in a stihl 026
It is in the circled location on the image below
This came from the manual located at http://www.stihlusa.com/stihl_ownersmanuals/026_Manual.pdf
If this helps please leave feedback
Posted on Feb 04, 2010
Will fire,wont stay running.wants to be full choked,open choke,it dies
Jerry, First thing to get is a new plug gaped correctly and try. Could need carb. adjustment, fuel filter replaced, bad fuel line(cracked/pinched), Dirt/faulty diaphragm in carb. plugged spark arrester in muffler,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://answers.yahoo.com/question/index?qid=20090528073906AA0y882
Chainsaw will only run with choke
Stihl Chainsaw starts but won run
http://tekindoor.com/miscellaneous/stihl-chainsaw-troubleshooting
May 28, 2016 | Garden
Can't start my stihl cainsaw I have changed gas,spark plug still no start
check the coil for if there is no spark it will never start.If you can't check the coil take the coil off,then take to a shop that can test it for spark and how strong it is.
Dec 14, 2013 | Garden
Ran out of gas put gas in wont start,pulled spark plug and put a little gas in ,it fired but wont stay running,the primmer bulb seems to be not working
Hate to tell you this but if you didn't mix oil with the gas properly (most likely a 40:1 ratio) then the chain saw will seize up and won't work again.
Jun 17, 2011 | Garden
Won't stay running, we changed the spark plug and changed the gas. will run for a few moments, if you turn the choke off or press accelerator it dies
HI,
Use a stiff piece of wire and form a hook on one end and use it to fish the filter that is on the end of a tube in the gas tank.Buy a new one and you should be back in business.Hope this helps and thank you for choosing FixYa.com.
May 19, 2011 | Homelite ZR10926 16" Chain Saw
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Weak spark hard start stihl 021
Check the pole gap on the ignition module to the flywheel magnets. Use a thin business card for a gauge. If it has the correct gap and you have tried a new spark plug, then the module itself is likely failing. Hope this helps!
Apr 14, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Doesn't stay running
start by cleaning the air filter, blow it out realy good, alot of times the carb gets dirty spray some carb cleaner in it just a little at a time, if you haven't changed the plug i would do that too.
Mar 15, 2010 | Oregon Scientific Oregon Chainsaw chain...
Stihl FS85 Weedeater
I suspect carb. trouble. Is the compression OK? Look at the spark plug after trying to start it. If it is wet, you are getting too much fuel. The white smoke indicates that. You may need to overhaul the carb.
Go on the Stihl site and customer service for information.
Sep 17, 2008 | Garden
Garden Logo
2,203 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
