Question about Tappan Kitchen Ranges
My range top gets hot but oven does nothing digatal control is dark checked voltage at wall and where connects to range
  • 612 Answers
You have a bad timer (Clock) you oven is controlled by the clock PC board.
Please rate solution
Posted on Sep 05, 2009
Why does the control panel on my Whirlpool electric range get too hot to touch when oven is operating at 350 degrees?
heat transference and radiated heat at that temp is normal
the stove should have an air gap between unit and wall
not pushed up against the wall
and internally insulated
check to see if your whirlpool model oven ever had a safety recall 26301150-vpuqtjtdvoowntuyvcl35auo-4-0.jpg
Oct 04, 2016 | Whirlpool Kitchen Ranges
Kenmore c970
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Sep 07, 2014 | Kenmore Stove / Oven / Range Bake Element...
Oven igniter doesn't work
called a spark igniter
Surface burners
The infinite switch
Apr 05, 2014 | Kenmore Ovens
Direct spark ignition wont fire on bake or broil
Surface burners
The infinite switch
The infinite switch
Apr 05, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
F1-1 reading on control board
F1:-1 may appear on your Gemini oven range for various reasons, but the meaning is always the same. The error means that the display relay control board thinks your temperature on your upper double oven range is running away and getting too hot. To fix the error F1-1, check the wire harness between your oven sensor and your control board to make sure the wires are secure and the connections are good. Pull the oven out and remove the back panel on the oven to check the wires connections. If the connections and wires check good, disconnect the wire connection to the oven sensor and check the resistance of the sensor. The resistance should be 1100 ohm at standard room temperature. If the sensor is not good you need to replace it, and if the sensor checks within range replace the display control board. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 09, 2013 | Maytag MER6772 Gemini Electric Kitchen...
I have a Frigidaire Electric smooth top range and oven. when I set turn on the burners they do not light up or get hot. When I try to bake I press the Bake button and set the temperture but the oven never...
HI.CONTROLS MIGHT HAVE BEEN LOOSE.oR LOOSE CONNECTION BETWEEN the control.Check the control connection inside .It might respond but connection has been loose.hope this helps..
Jun 21, 2011 | Frigidaire Microwave Ovens
Oven and Broiler coils do not heat. Control works okay. The burners heat okay. Set oven to 325 degrees. Drops to 100 degrees. There is a click. and nothing happens beyond that. Try broiler. Set to HI. Does...
There is a relay in the back panel of the stove, this is probably the problem, there is also a temp thermostat in the back leading to the inside oven this cold be bad
Nov 26, 2009 | Washing Machines
Oven does not work
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Mar 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Neither the stove top nor the oven get hot!
Hi and welcome to FixYa.com
First thing you want to check is the power supply (fuse or circuit breaker) to your oven.
Now, before you say "RescueTech it can't be the fuse because the indicators light up and I can set the controls!" read on-
Your range and oven elements are 220V units. This requires both legs of the 220 (L1 and L2) in order for them to heat up. Your indicator lamps and controls are 120V, therefore they will continue to work if one leg of the 220V feed is not present. It is very unlikely that all your switches and elements have failed at once. So start first at your fuse or breaker box. If you have cartridge fuses, you need an continuity tester or ohmmeter to check them. If you have breakers, there are two styles- One is a "single lever" style that controls both legs of the supply. The other style is a "double pole" breaker that is actually two separate breakers connected by a pin between them. Oftentimes one side will trip but not the other. You will actually be able to visually see this as the pin will appear crooked as one breaker is in the ON position and the other is in the TRIPPED position. Turn off the breaker (both sides will move together) and then reset it to the ON position. Now the pin should appear straight and both breakers should be in the ON position.
If the breaker seems to be fine, the next thing I would check is the terminal block where the range cord is connected to the appliance. As a journeyman technician, I often see where the installer failed to properly tighten the range cord's terminals when he/she installed the range cord. The appliance will function for awhile, sometimes for a few years even, but that connection gets HOT every time the range is used, and especially when the oven and all 4 burners are used together (Like on a HOLIDAY!) What will eventually happen is that the terminal will literally burn away and break the connection to one side of the 220. The result is anything "low voltage" on the appliance such as clock, lights, timers, indicators) will still work, however the elements will not heat up.
Before you start changing parts, check these things. I would be very curious to know how this one turns out. Just remember that the top burners and the oven have no connection to one another other than the supply voltage.
I hope this helps and have a happy and safe New Year from all of of here at FixYa!!
Dec 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
43 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
