Question about RCA RP5016 Digital Voice Recorder
I pressed a button and it locked. I don't know what button I pressed to lock it. I would like to unlock it please. And how do I erase the different folders?
    Problem Solver:
  • 4 Answers
Press and hold "MENU" to Lock/Unlock.
Posted on Nov 13, 2009
  • corvus24 Nov 13, 2009
    To unlock: Press and hold "Menu".
    You can't really erase the folders. You can erase individual files, by pressing "Erase" once, and then press it again. If you have "All" selected, pressing and holding will erase all files.
    If you really want to delete the folders, (assuming on a SD card) you can do that the same as any other in a PC.
    The Folders will be re-created the moment you select them while the SD card is in the recorder.
    You cannot remove the internal memory folders. without connecting by USB. In which case they will be recreated once you go to one of those folders on the recorder.
Samsung young locked?
Hi ,
If u dont want the data and if its okay if the phone is formatted then try this code it will surely work----switch off the phone first and press and hold volume down+menu button+power on/off button, u will get the option to full erase or format, select that option with the volume up/down keys and select by pressing menu or the power on/off button.
Jun 19, 2014 | Cell Phones
How to unlock htc
i locked mine and had to do a hard reset they had me hold down on the volume button while pressing the menu key it will erase all data in the phone up button on vol also on other phone by htc had to hold vol and power buttons down at same time erased everything
May 21, 2012 | HTC Wildfire Cell Phone
How do you erase the memory on a renualt key
ok here we go...... inside the key there is numbers. keys with 5 or 7 characters can only be programmed using diagnostic equipment. keys with 8 characters as follows
ign off, press central door locking button for more than 5 seconds
NOTE: doors should lock then unlock. in other words pull the button up and down.
carry out the following within 10 - 15 seconds
press first key lock/unlock button twice (some models once)
press second key lock/unlock button twice (some models once)
hope i helped
Jan 07, 2012 | Cadillac DeVille Cars & Trucks
My Luxpro psp511 ca is locked and I don't know how
TO LOCK THE KEYPAD: Start with the System Mode switch in either the
HEAT or COOL positions, and the Set Slide switch in the RUN position.
Perform a single press of each button, in the following sequence: NEXT,
NEXT, NEXT, HOLD.
TO UNLOCK THE KEYPAD: Start with the System Mode switch in either
the HEAT or COOL positions, and the Set Slide switch in the RUN position.
NEXT, NEXT, HOLD. The padlock should no longer be present, with the
thermostat now unlocked. If the padlock is still on the screen, please try
to enter the 4-button sequence again.
Jun 01, 2011 | Heating & Cooling
How can i delete the memos i recorded?
A.To ERASE
1st select the folder of deleting file(by pressing FOLDER button).
2nd press and hold " ERASE" button,
3rd within 10 second select the item you want to erase by rotating "PLAY/STOP SEL" wheel,
4th within 10 second press "ERASE" button. selected item is erased.
if this method will not work, then , the item is locked. To remove the lock folow below step B
B.TO UNLOCK
1st select the folder containg the item ( by pressing FOLDER button)
2nd press MODE button until " LOCK" or " UNLOCK" flashes
3rd within 10 seconds select the item by turning "PLAY/STOP SEL" wheel
4th within 10 seconds press the same " PLAY/STOP SEL ' wheel
item will unlock
then for deleting folow method A
below link is user manual
user manual panasonic RR-QR240
best of luck keep smiling
Jan 14, 2011 | Panasonic RR-QR240 Handheld Digital Voice...
Osdlock on my computer desktop for 17'' monitor
You are having a problem with the OSD lock on your ViewSonic E70f Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | ViewSonic E70f 17" CRT Monitor
OSd lock keeps on poping up on my screen, i ihave viewsonic monitor. how can i solve this problem?
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
Mar 28, 2009 | ViewSonic E70f 17" CRT Monitor
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Dec 24, 2008 | 2004 Volkswagen New Beetle Convertible
RCA RP5016 Digital Voice Recorder Logo
236 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
