Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Trying to fix nephew's notebook. The computer is getting no power. It is not his power cord as I have a backup multi power cord I connected to it with the same results, nothing. I have no problems working on desktop's, never fixed a notebook before. Any help is appreciated.
    Genius:
  • 1,019 Answers
unfortunately laptops are a lot more technical. as most of the components i.e graphics chip-sound chip et,c are built onto the motherboard. heres a couple of ideas. remove the battery then plug in the charger, this will determine a damaged battery cell. possibly shorting out. then i,d try to dharge the battery on a same/similar model laptop if possible. or borrow/buy a spare. some laptops have a seperate charging circuit board, attached to the motherboard. this may have a faulty component. if your competant with electronics. you may be able to download a service/repair manual. to enable the dissasembly of the laptop. if you deciide to go this far. i,d suggest looking for a small fuse, close to the power inlet socket. possibly marked F1. if this has blown, that will be your problem.
Mike @ compurepair.
Posted on Sep 05, 2009
    President:
  • 2,600 Answers
There are several issues that can cause the no power issue you have. You have started at the simplest and now we need to work our way into the machine. The first thing is to check the output voltage that these power supplies are giving to make sure they are within the voltage requirements of the laptop, next is juice getting to the ac jack and is that voltage still the same? If so, then I would check it at the out-going legs of the jack where it solders to the motherboard...jacks have been known to go bad as in cold solders etc. If the jack is attached to the motherboard via a cable, check the wiring, plug, possible chaffing, does the power plug fit firmly in the jack socket? If you have power all the way to that point, then the issue is terminal for the motherboard unless you take it to a professional shop for diagnose and repair. It will probably involve an integral part of the PSU handling capability of the motherboard.
  • 855 Answers
If the battery shorted out the power cord won't work. Try checking the battery and the connection.
Cq50 flicker
Disconnect the power cord and battery. Hold down the power button for a minute and then connect only power cord.
If not fixed:
Please scan your computer with free version of superantispyware:
http://www.superantispyware.com/
IF not fixed: It is a screen hardware issue.
Jul 09, 2013 | Compaq Presario CQ50-215NR Notebook
Sound installer for gateway loptop 6518gz
Easiest for your..
Automatically Detect, Download, Backup, Restore and Uninstall Drivers.
Fix your Driver Issues.
  • Automatically Detect Unknown Device Drivers
  • Keep your Drivers Up-to-Date
  • Over 1,000,000 Hardware Driver Database
  • Driver Backup, Restore & Uninstall Features *
  • FREE for Personal Use
  • Multi-Language Interface *
  • Extremely Easy-to-Use Automatically Detect, Download, Backup, Restore and Uninstall Drivers.
Download & How2use:
http://www.drivereasy.com
Please rate my solution.
Thank you for using FixYa.
Jun 23, 2011 | Gateway 6518GZ Notebook
When you move the computer working under external
issue with the ac jack. It has a loose connection. you will need to open up the laptop and remove the board to re-solder the AC jack.
Jun 02, 2010 | Acer Aspire 3000 Notebook
Bought a new power cord because I had to keep moving cord around to get battery to charge, move and would lose charge received new power cord and still have to move cord around to keep getting a charge...
First thing you need to do is STOP trying to wiggle the cord to make it work. You could damage the motherboard.
The power jack needs to be replaced. It's a pretty standard repair. You can try finding a local laptop tech from Craigslist or visit your local shop.
This type of repair usually runs 70-100 out the door (depending on where you live)
I don't recommend you trying to fix it yourself.
Apr 03, 2010 | Dell Inspiron B130 Notebook
Computer will not stay powered on...power cord not keeping good connection.
Power cord could be bad. I bought a multi-pin power cord from Walmart for $100 (so it would work with any of my laptops).
If it isn't the power cord it could be in your boot up.
Feb 15, 2010 | Acer Computers & Internet
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Coputer wont charge even when pluged in
This is a commom problem.
Problem with power socket on the laptop, it may caused by a dry solder joint and needs to be resoldered or the power socket may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars.
If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Jun 30, 2009 | Dell Inspiron E1705 Notebook
Computer seems to be restarting endlessly
Its seems any one of the key of your got stuck. So please check out your keyboard first.
If problem still not fixed then, try to re-install your RAM: remove the RAM clean its connection point to the board, and placed it agin gently. then try to re-boot.
Please let me know your feed back.
Thanks
Iqbal
Mar 29, 2008 | Computers & Internet
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
70 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
