Question about Canon PIXMA MP130 All-In-One InkJet Printer
Error 5200 same as the rest of the messages.  Can't get the printer to operate, have tried everything I can think of.  May just throw it away and buy a BROTHER
  • 4 more comments
  • Anonymous Mar 12, 2008
    errore 5200 ho provato a staccare la spina con la stampante accesa, e rimuovere la testina, poi ho riacceso, mi ha richiesto di nserire la testina di stampa e l' ho reinserita ma mi da lo stesso messaggio " controllare stampante (5200)
  • Anonymous Apr 09, 2008
    what i do is unplug the printer then plug it in again. then i guess it resets itself and i can start printing again.
  • sjhewish Aug 14, 2008
    My printer is Canon PIXMA 130 and the screen reads.
    Check printer ( 5200 )
    How do I overcome this problem.
    Stan Hewish.
  • Anonymous Sep 05, 2008
    hola buenas tardes mi impresora presenta el mismo problema 5200 que hago
  • sandkslater Oct 23, 2008
    have error 5200 on printer before I turned it off it had error 5600
    I can not win hope you can help .
    thanks
  • kjheeramun Mar 22, 2009
    I have a Canon Pixma MP 460 printer. When I launch a print it displays 'ERROR CODE 5200' on the printer. The on/off button blinks green and the alarm blinks amber.
    How could I get rid of this problem and start printing again?
    Thanks for a reply.
    Regards
    Jake
My printer is not working. its showing error(5200).what can i do to solve this problem.
Posted on Feb 15, 2011
Canon MP250 series Printer.
SAYS ERROR CODE 5200. ON.OFF BLINKS GREEN AND ALARM BLINKS AMBER. HELP
Posted on Feb 14, 2011
Try this it's work
Posted on Jan 12, 2011
After error5200...error5600
Posted on Apr 02, 2008
Well I had the error 5200 popping out on my printer screen and guess what, I did the plug in and plug out thing. It worked in the first place but then didn't. Then I decided to replace the color ink since it was low and I previously had already replaced the black ink. And guess what?! After I replaced the color ink, the error disappear and I could now print. Hope this is another solution you guys could try. It worked for me.
Posted on May 09, 2010
  • fatfarmer Apr 04, 2011
    We kept looking for the print head to remove as in Solution 1, but when we could not figure out how to do it, I looked on down to this solution. I too had previously replaced the black ink but not the colored. When I did this the printer worked. !!!!! Thanks for the info.
Dear sir or madam;
I have a Canon Pixma MP110 Printer. I had a problem (5200). And I read your directions. My printer is O.K. now. Thank you very much for your help...
Huseyin YAZAR
IZMIR - TURKEY
husoyazar@hotmail.com
Posted on Mar 13, 2008
    Problem Solver:
  • 10 Answers
I went to a local ink store and they told me if the ink cartridge is used to much after it is low or out of ink that it will burn up the head and then it will display this message. I refilled my color ink cartridge even though I was not using it and it worked as soon as I put it in.
Posted on May 25, 2010
  • 70 Answers
I solved this problem by replacing ink cartridges. thanks for suggestions.
How I reset Error 5200
Posted on Oct 07, 2011
  • savvas_kotri
    savvas_kotri Mar 16, 2013
    You save me!! Thank you!!
Thank you for Solution #2. My MP130 had a "service code 5100". It kept telling me that the print head was not set properly even after resetting it several times. But I did as you said and it fixed the problem.
Posted on Aug 25, 2008
Any driver for error 5200
Posted on Apr 16, 2011
    New Friend:
  • 37 Answers
You need a resseter to solve the problem
Posted on Jan 03, 2015
    New Friend:
  • 6 Answers
CARRAGE SANKRANTA PROBLEM
Posted on Aug 30, 2014
Dear All,
Thanks to all you geeks with such a nice helping heart. I did read your suggestions and then re-filled my Color Cartridge, and put it back on. After that every thing is working just fine.
Ever grateful,
Imtiaz Hassan Sohel
E-mail: sohelimtiaz@yahoo.com
Tel: (213) 842-2777.
Los Angeles, California,
USA.
Posted on Oct 17, 2012
I've followed your instructions....................have asked my printer to print................and IT WORKS WAHEY!!
It's still telling me that the waste ink absorber is full.......................if i knew where it was or how to get to it i'd empty it.
Posted on Sep 22, 2008
  • Rodante Panes Jan 18, 2011
    waste ink absorber is full, means it reached its limit, you have to reset it and use a resetter, canon service centers has it but you can also try looking over the net for the cannon resetter and download it. I have an experience like this and brought my printer to cannon service center, there i found out that it is only a software based problem.you can reset it yourself if you can have the canon resetter for your printer.
Thank you so much...this is the only solution that I could get to work!!
Posted on Mar 19, 2008
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working..... ;)
Posted on Dec 19, 2007
  • 3 more comments
  • Cool Guy1 Sep 09, 2010
    Excellent, it worked. The 5200 error message is not there anymore. Thanks alot.
  • justv Sep 24, 2010
    i had do try it 3 times but on the 3rd attempt it worked for my MX860 i used all new ink cartridges thank you!!!!
  • jshin_1123 Mar 31, 2011
    It worked! But the next day when i wanted to print, the same error shown again...
  • Igor Mayer Radovanov Apr 11, 2011
    How Reset Canon PIXMA error 5200:
    The printer is turned off and plugged the power cord.
    Press the button STOP / RESET and hold, then press and hold the POWER button.
    POWER button is pressed, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed.
    Release both buttons simultaneously.
    Press the power button, then the printer will off
    Press the power button again, then the printer will be lit and ready for use.
    Press the power button, then the printer will die.
Error 5200 in canon pixma ip2772
Hi
Your printer may need servicing.
Check the cartridges installations and make sure they're properly installed.
Try cleaning the print head too.
Mar 02, 2012 | Office Equipment & Supplies
Waste ink absorber full
Hi!!
Bad news!!If that error comes up you can throw it away,its reached end of life,even the manual says replace the printer as it has failed!!Think it will be cheaper buying a new one than having spares replaced on the machine!!
Sorry!!
Sep 20, 2011 | Canon PIXMA iP1600 Printer
Service error 5200 Keep getting this message Have
Your printer might be running out of ink, if you've seen that the ink button blinks, youy need to replace your cartrudge or refill your ink.
Jul 03, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Getting an error message 6500 on a canon ip5200
my printer found this problem error 6500 my printer model is canon ip 5200 what do i do?
Apr 27, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
Black ink failure
The ink is dried up in the cartridge.
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
ERROR MESSAGE
remove rests of older installations from registry:
search for "seiko" and remove everything you will find.
reboot + run setup
Nov 12, 2008 | Seiko Smart Label Printer 100 Thermal
Canon PIXMA MP130 All-In-One InkJet Printer Logo
61,682 people viewed this question
old marine
old marine
