Question about Dell 926 All-In-One InkJet Printer
Dell 926 all in one printer. err: remove tape from carttidge
Error message says remove tape from cartridge, but tape has been removed and cartridge is new. this seems to be a very common problem as per other forums, but can't find any solutions
  • yowillieo Sep 05, 2009
    how do i veiw the solution??!!!
    how am i supposed to veiw the solution???!!!
My DELL AIO photo 926 is telling me to remove tape from cartridges, how do I do that or how to solve this problem? i have new ink cartridges in already
remove the tape from the cartridges, it has tape on the contact point of the cartridge, pull them out again and double check dell printer
Dec 09, 2011 | Dell 926 All-In-One InkJet Printer
I have a Dell Photo926 printer. I just changed the color ink cartridge and it is giving me an alignment error stating remove tape from cartridge. There is not any tape on the cartridge. I have ran the...
Are you using Dell Series 9 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
You are using Dell Series 9 ink cartridges, correct?
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Apr 26, 2011 | Dell 926 All-In-One InkJet Printer
I ran out of ink and replaced my cartridges. When I tried printing the alignment, it printed the alignment, then gave me the error message of ERROR 2200 and also says "Alignment problem. Remove tape...
Try cleaning the Gold section of the cartridges with a wet paper towel.
Unplug the printer and clean the gold contacts on the printer where the cartridge meets up to the printer with a wet paper towel. Do this till the towels come back clean.
Dry both the contacts on printer and cartridges.
Allow at least 30 mins for the printer to dry.
Plug the printer back in and reinstall the cartridges.
Align the cartridges,
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Dell 926 All-In-One InkJet Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
    Follow the below instructions
    1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
    2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
    3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
    4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
    5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
    6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
    7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
    I hope this clears up your problem.
    Good Luck and Have a Nice Day!!
    Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
    Cartridge alignment problem - it says to remove tape from cartridge or troubleshooting. There is no tape on the cartidges.... HELP!
    Rick
    Jan 09, 2011 | Dell 926 All-In-One InkJet Printer
    Dell all in one 926 printer after replaceing the
    If you used a refilled cartridge go back to Dell OEM. If not then pull out the cartridge and clean the carriage it sits in and make sure you removed the tape. then power off and back on again and let the printer reset.
    Apr 14, 2010 | Epson Printer
    Error 1203 for Dell Printer AIO 926
    Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    or
    2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
    Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
    New cartridge installed printer gives message that
    Check both cartridges, one might still have plastic film that needs removal.
    Dec 17, 2009 | Dell 926 All-In-One InkJet Printer
    Alignment of my Dell 926 printer
    go into control panal select printer, than high light the printer you want,than go down to printing preferance and go to maintance and select the one that fits you best needs.
    rod
    Feb 06, 2009 | Dell 926 All-In-One InkJet Printer
    Dell 926 All-In-One InkJet Printer Logo
    456 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
