Question about Jackson 25 in. TempStar HH-ST Free-standing Dishwasher
What ton is my tempstar pgf048k080a a/c unit - Jackson 25 in. TempStar HH-ST Free-standing Dishwasher
  • 135 Answers
Look for the BTU rating. 12,000 BTU is a one ton unit.
Posted on Sep 05, 2009
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Identify heat pump by model #
2.5 ton. Hope this is what you are needing answered
May 24, 2015 | Heating & Cooling
Tempstar 5000
The 48 before the VKD in the model number stands for 48000, BTU. For refrigeration, 1 Ton = 12000 BTU. Therefore 48000 BTU / 12000 (1 Ton) = 4 Tons
May 03, 2013 | Heating & Cooling
Trying to find ton rating for a Tempstar 9000 mod# CA903VKA2.
If this is a window or portable unit, you will not find the tonnage only the BTUS. My guess is 9,000 BTUS
3,000 less than a ton
Jun 17, 2010 | Heating & Cooling
I have a tempstar 5ton 13 seer a/c unit. It keeps freezing up. I have check the freon, the filter and even put a larger blower motor on it. What else could be the problem?
The problems cold be to small a return air. I do a lot of cool surveys where I check the efficiency of the AC. Some people are putting in Heppa pleated filters and they realy restrict the air flow a great deal. You need at least 1.25 square feet of filter area per ton. 5 ton should have 24 by 36 return. Check to see if coil is dirty. Check air temp. across coil. From return to closest vent. Should be between 18 to 23 degress. Rusty
Jun 03, 2009 | Heating & Cooling
Dishwashers Logo
300 people viewed this question
Top Jackson Dishwashers Experts
jhnolson
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
