Home | HP | Server Tc2110 | Disk I/O Error: Sta...
HP Server Tc2110
Problem for HP Server Tc2110
Disk I/O Error: Status = 00008001
By jay_ar4 on Sep 05, 2009
I have windows 2000 server, then it so happen that one day it automatically shutdown,and my server is on RAID..but the problem is i cannot go to windows startup, i cant even pressed F8... The two hard disk is not functioning even if it is in RAID..and lastly when i tried to boot to CDROM with my bootable CD, i got an error with DISK I/O Error : Status = 00008001
What does this mean?And how do i fix this problem...Any help please........
By the way, my server is HP tc2110.
Comments:
Sep 05, 2009
- RAID 1 and its SCSI and also its software.. How can i fix my system? Thanks for your immediate reply...
Sep 05, 2009
- i tried exactly what you said to clean up my system unit, im using compressed air to clean up the dust inside but nothings happen, the error still persists. Another additonal info with regards to my server, last day, we have power interruption and it so happened that our UPS cannot supply enough power to my server, but only one server is shutting down that day that is my hp tc2110 server. So i started it up, then before it goes to windows startup, i heard a long beep and it cannot be stop. But when im in the windows startup, i got an error says that "Windows could not start because the following file is missing or corrupt: \Winnt\System32\Config\Systemced startup options for windows 2000, press F8. You can attempt to repair this file by starting windows 2000 setup using the original setup floppy disk or cd-rom. Select 'r' at the first screen to start repair." This is the entire message appear at first. So, i boot it with my original windows 2000 bootable cd, but i found out that i cannot even press the recovery console or 'r' for repair but instead it says that the "windows cannot locate the system into your drive. Press F3 to exit setup". Then, i tried fixing it through Hardware matter. I dettached SCSI to my other Hard Disk drive which is in RAID, i only used one Hard Disk Drive at this time and i found out that it works with one Hard Disk attached, so the next things i did is dettached the Hard Disk Drive which is my currently used drive and attached again the second Hard Disk Drive but i found out that the problem "\winnt\system32\config\systemced" which is i discussed while ago, i found it in the second drive. So, i made a conclusion that the problem is on the Second Hard Disk Drive, but when i tried using the first Drive which is working Drive, i found out that it halted. Which means, that i cannot go to startup windows, and i got another error that says " Disk I/O error: Status =00008001". Take note that this is my working drive which i tested while ago.. I tried using windows 2000 bootable CD to fix this problem but i cannot proceed to recovery console, and even if i tried to format or reinstall the Drive, i also got an error which says " The windows cannot locate the system drive. Press F3 to exit setup." I dunno what to do.. Please help, Thank you in advance.
Sep 05, 2009
- Another additonal info with regards to my server, last day, we have power interruption and it so happened that our UPS cannot supply enough power to my server, but only one server is shutting down that day that is my hp tc2110 server. So i started it up, then before it goes to windows startup, i heard a long beep and it cannot be stop. But when im in the windows startup, i got an error says that "Windows could not start because the following file is missing or corrupt: \Winnt\System32\Config\Systemced startup options for windows 2000, press F8. You can attempt to repair this file by starting windows 2000 setup using the original setup floppy disk or cd-rom. Select 'r' at the first screen to start repair." This is the entire message appear at first. So, i boot it with my original windows 2000 bootable cd, but i found out that i cannot even press the recovery console or 'r' for repair but instead it says that the "windows cannot locate the system into your drive. Press F3 to exit setup". Then, i tried fixing it through Hardware matter. I dettached SCSI to my other Hard Disk drive which is in RAID, i only used one Hard Disk Drive at this time and i found out that it works with one Hard Disk attached, so the next things i did is dettached the Hard Disk Drive which is my currently used drive and attached again the second Hard Disk Drive but i found out that the problem "\winnt\system32\config\systemced" which is i discussed while ago, i found it in the second drive. So, i made a conclusion that the problem is on the Second Hard Disk Drive, but when i tried using the first Drive which is working Drive, i found out that it halted. Which means, that i cannot go to startup windows, and i got another error that says " Disk I/O error: Status =00008001". Take note that this is my working drive which i tested while ago.. I tried using windows 2000 bootable CD to fix this problem but i cannot proceed to recovery console, and even if i tried to format or reinstall the Drive, i also got an error which says " The windows cannot locate the system drive. Press F3 to exit setup." I dunno what to do.. Please help, Thank you in advance.
Sep 05, 2009
- Sorry for double post, my internet connection here is hanging up by that time..
Clarification Request
Posted by oloo on Sep 05, 2009
Need more info. What kind of array, RAID-0, RAID-1 ,,, ? Hardware or software RAID ? SCSI, IDE ? Any other HDs on installed?
Best Solution
posted on Sep 05, 2009
Helpful)
muebe
Rank: Guru
Rating: 90%, 250 votes
Some simple things it could be...Check the screws on the mainboard holding it to the case. The mainboard uses these screws to ground the board and sometimes they can loosen up from heat & cold expansion over time. Also dust is conductive and if enough gathers on the board it can cause problems also. So use some compressed air on the mainboard to clear out the dust. And also a power supply going bad can cause problems like this. If you have another computer with a working power supply try swapping it out and see if that works. More info on the setup would be helpful.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you so much " - jay_ar4
Solution #2
Not Rated)
oloo
Rank: Guru
Rating: 86%, 25 votes
POssible:
Do you have a Zip drive attached to this server?
If so, Disconnect it & see if server will boot.
Was this helpful?
Yes
No
Popular Solutions for HP Server Tc2110
Questions and Unsolved Problems for HP Server Tc2110
Do you recommend HP Server Tc2110?
Answer
Answer
i have a problem with forwarding ports on Orange LiveBox mini for a game server
Answer
how do i unlock a laptop given to me by the council to msn
Answer
how come every time i download limewire in try to run it always say no connection.but when i ask... (More)
Answer
hi, am getting amber color in my HP server. help needed urgently
Answer
i keep getting kick off games whats going on its on madden ps3 2010
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Server Tc2110:
Top Server Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Server Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
