Question about Sampo P7011M (Silver) 17 in. Flat Panel LCD Monitor
Screen does not turn on but green light is on.
  • 5,660 Answers
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Posted on Sep 05, 2009
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
TV won't turn on.
your mainboard is damaged, to order a new one you will need your product code and model, both located in the back of the TV next to the serial number
Jun 05, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
While im plaing my psp, the screen freezed and i restarted it, when i turned on my psp (theres a green light) nothing happens the screen is empty then a few minutes the green light gone what happened
I guess you have custom firmware. If so, you can use a pandora battery to solve the problem. If you do not know how to make a pandora battery or if this doesn't work send me an email or add me on eclipse_09_28@hotmail.com. But pandora is most likely to be the solution. I had the same kinna problem but I was updating it thats the only difference. The green light is on and the screen was blank and then the light turned off. So I used a Pandora Battery and it fixed. :P
May 24, 2009 | Sony PlayStation Portable (PSP) Console
Ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Nov 17, 2007 | Sony PlayStation® 3 (60 GB) Console
Psp green light on but now screen
Try Holding the R trigger and turn the power on at the same time. This puts you n a diffreent mode, then press the display brightness button to see the version. Power off and back on agin to see if that resets it. This is only a guess I would appreciate at least a thanks for trying.
Nov 04, 2007 | Sony PlayStation Portable (PSP) Console
Sampo P7011M (Silver) 17 in. Flat Panel LCD Monitor Logo
174 people viewed this question
Top Sampo Computers & Internet Experts
Paul Bade
michael galang
Are you a Sampo Computer and Internet Expert? Answer questions, earn points and help others
