I just bought a 1992 toyota camry and the radio doesn't turn on. None of the screens or light turn on. I removed the radio and all of the wires look clean and fine. However, it does appear that the antenna has broken off at some point. Also, the radio is the stock combo that I assume came with the car.
No sound to radio speakers?, is there power to the radio, should have 2 wires with 12 volts with key on and one with key ff.
No there is no sound to the speakers. There is also what seems to be an aftermarket remote starter. I don't know if that would cause some sort of electrical interference or not. I don't have a voltage tester on had. I was going to install a new CD player anyway, should I try to hook it up and see if it is just the factory radio?
I was able to find a voltage meter, and I checked the wires for voltage. From the wire with key off, there was 11.08 volts. When I turned the key on, there was 0.00 volts from both. Also I would like to say thank you for your responses.
