Question about Microwave Ovens
We have a whirlpool over the stove mounted mw/fan
We have a white whirlpool over the stove mounted combination microwave/fan. we have lost the bracket(s) and screws to re-install. where can we get replacement ones, we live in vancouver bc canada. thank you
  • 45 Answers
Try this link....
http://www.partselect.com/Whirlpool-Parts.htm
or more detailed....
http://www.partselect.com/AppliancePartList.aspx?Brand=Whirlpool&Appliance=Microwave&ModelNum=&Type=Not%20Sure&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Posted on Sep 05, 2009
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Have a Whirlpool MW Model MH6600XV with a vent hood; last night the vent went on by itself and I was unable to turn it off except by the circuit breaker; turned the breaker back on this morning and the...
If you got it hot enough from your soup there is a fan switch to turn the blower on to cool the unit. Maybe next time cook that on a different burner on the stove to try to not heat up that area under the microwave.
Sep 17, 2017 | Microwave Ovens
How to uninstall a Whirlpool microwave Hood Combination? Model MH6600XV
Unplug the range and move it out of the way.
Open the cabinet above the microwave.
Unplug the power cord.
Remove the 2 bolts going through the cabinet into the top of the microwave.
Have a helper hold the microwave in place before these bolts are removed.
After the bolts are out,assist the helper by lowering the front of the MW and lift the back of it off the mounting bracket attached to the wall.
They are heavy and awkward.
A helper must be used.
Jan 21, 2011 | Microwave Ovens
My Whirlpool microwave hood combination was installed when I bought my home. I can hear the exhaust fan run when I turn it on but it does not pull any smoke, steam or odors from the stove top. I can put...
sounds like they forgot to flip the vent louver,
it sits atop the microwave and needs to be rotated to the proper direction for venting.....
Oct 13, 2009 | Microwave Ovens
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Jan 29, 2009 | Whirlpool Microwave Ovens
Fan on over the range microwave does not have enough suction to **** the steam from stove through the microwave. Does the blower get turned a certain way for this to work? Is there a .pdf operational...
This may be caused by a weak fan, improper installation, clogged filters, blocked air ducts, or a blocked outside vent.
Assuming yours is a Whirlpool, you can download Whirlpool owner's manuals and installation instructions here.
This will help you check the mounting and setup, as well as helping you check the filters to see where the problem lies.
Please write back with your brand and model number if you yours is not Whirlpool.
Jan 02, 2009 | Whirlpool MH1170XS Microwave Oven
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave
It sounds like there may be a blown fuse. The back of the mw oven will have to be removed to check. Some ovens only have a thermal fuse and not a traditional glass fuse. If that is the case you should call a technician to repair it unless you know how to use a soldering iron.
Dec 26, 2007 | Microwave Ovens
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
