Question about Bose 3·2·1 II System
System won't turn on
Push the power button, no response. Check all connections and unplug from the wall and wait, no response
  • 53 Answers
Check fuse inside unit
Posted on Sep 05, 2009
Connection
  • Step 1 check all connections, and make sure they are in right position and well connected
  • Step 2 turn off the power of both router and modem. (unplug the power supply). Sometime the modem has battery in them as the back up power, then you need to find the reset button (use a pen) and push that button.
  • Step 3 wait 3 minutes.
  • Step 4 turn on the modem(if it does not have battery in it)
  • Step 5 wait 3 minutes.
  • Step 6 Turn on the router.
Hope this will hlep!
Jul 09, 2013 | Computers & Internet
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
I unplugged from the wall. Now I have an error
Hai,
The Ink delivery system is malfunctioned, please perform below troubleshooting to fix the issue.
Power Drain:
1.Press the On button to turn the printer off.
2.Unplug the power cord from the back of the printer.
3.Remove all the ink cartridges.
4.Wait two minutes.
5.Plug the power cord into the back of the printer.
6.Press the On button to turn the printer on.
7.Install the ink cartridges when prompted.
If you still get the same error message (0x code on display) reset the printer.
Reset the Printer:
1.Remove the ink cartridges from the printer, close the cartridge doors.
2.Wait for 30 seconds and disconnect the power cable from the back of printer, while the printer is ON.
3.Press and Hold "OK" and "Cancel" key, while holding them, insert the power cable behind and keep holding them for 10 seconds and then release.
4.If the printer goes OFF, push ON button to turn it on.
5.Then insert the cartridges when the display prompts and check the printer.
If the 0xc18 or 0xc19 ink system error code displays on the front panel, service the printer.
Thanks & regards
Rizwan.
Jan 31, 2010 | HP Photosmart 3210 Printer
Printer Error Message HP AIO 6210 printer
Hi
If you find the lights flashing, we could try resetting the printer.I have explained the reset procedures below
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Thanks
Riz
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My hp 3310 wireless printer freezes and displays a blue screen (on the printer) with alpha numeric characters
Hi
Try resetting the printer
(Notes - resets will take a while)
Thanks
Riz
Dec 29, 2008 | HP Photosmart 3310 Printer
Error codes
Hi
The error code 0x....... states IDS (Ink Delivery System) failure.Its an Hardware issue with the printer.
This problem could be resolved by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off don't worry release the button and Push the ON button.
Thanks
Riz
Dec 28, 2008 | HP Photosmart 3310 Printer
New printheads and cartridges but not printing only blank sheets
IDS (Ink Delivery System) failure is not related to the print heads at all. It pertains to that delivery system that lies between the Print head and the Ink Tank. Its a Hardware Issue, some ttime it gets fixed by resetting the printer.
Follow the below steps.
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER button and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Thanks
RIZ
Mar 05, 2008 | HP OfficeJet d145 InkJet Printer
HP Officejet G85xi with no power
Hi..
You can try to reset the Printer to factory settings.Just follow the below steps, dont worry my steps will not mess your printer , as i was HP tech support for All in One printer for 20 months.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait for 40 second then release the buttons.
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait for 40 second then release the buttons. Push the ON button and check.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold ENTER/OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons for 40 seconds ,then release the button and Push the ON button.
Please try the steps and let me know the result.Waiting for good reply from u.
Cheers
RIZ.
Feb 11, 2008 | HP G85xi All-Color InkJet Printer
HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know after resetting.
Thank U!!
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
Chatters
i belive that your printer needs to be resetted. Just try the reset options which are for HP 6110xi.
Thank You
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Bose 3·2·1 II System Logo
151 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
