Question about Kenmore HE2 Plus Front Load Washer
I have the same problem F35 error, SUD message.
Washer approx. 15 months old. Started buzzing, gave an F35 error. Only way to reset is unplug. When restarted get a SUD error. Have to run through a rinse & drain cycle.
    President:
  • 1,776 Answers
This typically indicates slow drain condition. It's not only if the water drained, but how quickly it drained. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Posted on Sep 05, 2009
WHIRLPOOL DUET WASHER MODEL #WFW9600TW01 F-35 & F-28 ERROR
The F35 indicates a water level pressure sensor failure. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced. I hope this helps.
also for the F-28 issue
http://fixitnow.com/wp/2011/06/30/how-to-troubleshoot-an-f28-error-code-in-a-whirlpool-duet-sport-washer/
Oct 28, 2014 | Washing Machines
Ok I had my pump replaced a few weeks ago but now I am getting the sud and f35 and f28 messages. What shouli do anjow much is the switch?
Try this one to remove the error display f35 and f28
Press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
Jun 03, 2011 | Whirlpool Washing Machines
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a HE5t kenmore elite front loading washer. It has done great for about 15 months. We were away for about 3 weeks, and since we have returned, I put in a load of clothes, and it tries to start...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%^*
Aug 27, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE5t Error Code F35
we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
266 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
