Question about Lexmark X4650 InkJet Printer
I purchased a new Lexmark X4650 printer and am in the process of installing it on my computer and connecting to my wireless network. I have identified the correct wireless network and entered the correct WEP key but I keep getting "Connection Failed: your printer could ne be connected to your wireless network". The wi-fi light on the printer is solid green. I am stuck here.
  • Anonymous Mar 12, 2014
    I chose the right network, entered the correct password, but printer will not connect
I recently purchased a Lenovo All in One wireless computer. I've plugged in the USB cable as per instructions but my X4650 printer will still not print.
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Dec 13, 2014 | Lexmark X4690 Wireless InkJet Printer
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
I want to set up a wireless printer connection, but I lost the installation CD.
Please visit the Lexmark website to download and install the Lexmark X4650 printer driver on your computer. Select your operating system > download > execute the file. Just follow the instructions on your computer screen.
Sep 19, 2011 | Lexmark X4650 InkJet Printer
Hi their, im matt Right, i reinstalled everything on my computer because i wanted to start a fesh installation. Im running windows 7 ultimate 64bit. I have tried to reinstall my printer but no look. I...
Check if your printer is still connected to the same network as your computer. Refer to this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If you the printout, check the SSID and other network information. If printer still belongs to your network, then it could be a firewall issue. Make sure to allow all Lexmark and printer communications in the program rules/permissions for your firewall. If printer doesn't belong the same network as your computer, then you need to reset the printer's wireless network adapter and re-launch the Lexmark Wireless Setup Utility. How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults
May 29, 2011 | Lexmark X4650 InkJet Printer
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
No wireless printer port for lexmark x4650
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
Feb 03, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
226 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
