This problem should be removed because:
Problem with Canon CFX-L4000 Plain Paper Laser Fax
"always getting check paper size"
I have canon fax cfx-L4000 during receiving is only one page printed then showing check paper size alarm, i pulled out the paper tray, insert again then print one page after that showing again check paper size, do you have any suggest for me what the problem so that i can fix myself, thanks a lot for the help.
Solutions (4)
the sensor flag at the rear paper path sensor is worn down too short. i have seen this many times
I did even the setting is correct, i'm using a letter LTR paper size but its always getting show check paper size after printed one page. I was suspected the sensor switch from down before passing way to the pickup roller but i'm not sure if is it, do you have any more advise? Thanks a lot!
Thank you very much for the response
the paper size you are using is incorrect.
1- when you take out the tray is the the paper snug in the tray? is the paper adjuster set to LETTER, is there a switch for custom and letter? is it set to letter?is it set to letter in the menu?
here is how to check the sensor :
change to legal size does it register as legal ? if no then the sensor is out of place or bad.
I saw that you are in Europe, is that correct?
to my understanding they use a different type of paper, they use A4 size which is a smaller size than Letter.
If you are using Letter size, my suggestion is to try and reset the machine and start over with the settings. ( if you have the manual)
Did you try to change the size of the paper? did it register the different size?
I just fixed same problem on my LaserBase MF5730 device when printing PDF file of not standard (A4) size.
Make sure that "Choose paper source by PDF page size" is unselected in your printing settings dialog.
Received in Memory
I have issues!! My alarm light is blinking, the screen is saying paper jam, but there is no paper in the machine, only in the tray. My...
Canon CFX-L4000 not receing faxes.
I have a Canon CFX-L4000 that is not receiving faxes. It just blinks check printer ##322 and the Alarm light it on. I have tried replacing...
Cannot insert the paper tray
The paper lift are for the paper feed is raised and will not lower so the paper tray can be inserted.
I am getting the alarm
I am getting the alarm "check paper size" and then it jams.
Add Your Solution
how to send fax to a efax number
Trying to send fax to an efax number: When I key in the fax number on the Canon CFX-L4000, the dial ring tone came on...
When releasing the lever that sits on top of the...
When releasing the lever that sits on top of the paper tray when you slide it in, noticed a round black spongy wheel. ...
How to automatically receive fax? What's the
How to automatically receive fax? What's the settings?
Fix-O-Meter
820
820 people viewed this problem
- 0 people are following this problem. Be the first!
Top Canon Fax Machine Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
