Question about Garden
Front tires are bent out left worse than right. When you turn the steering wheel one tire seem to turn more than the other.
  • 53 Answers
Sounds like wheel bearing
Posted on Sep 05, 2009
My steering wheel is shacking at 35 - 50.
tires need balanced or wheel rims bent
Mar 10, 2015 | 2006 Toyota Sienna
Noise from right front tire
jack up front left on level ground ,support and chock rear wheels and set park brake ---look and check the cv axle for leaks,tears or damage -put in neutral and watch axle should turn smoothly turn steering wheel to left and rotate tire again watching axle if their is binding or grinding or studder movement than axle is damaged and needs to be replaced
Apr 08, 2014 | 2005 Ford Freestar
Whining from front left seems to be the tire, steering wheel slightly vibrates when turning left
If you swerve the car back and forth and the sound dissapeers when swerving to the left( reducing the weight on front left tire) this could indicate a wheel bearing problem
Sep 03, 2012 | Ford Edge Cars & Trucks
Whining from front left seems to be tire, turning to the left gives slight vibration in steering wheel
sounds like you have a bad wheel bearing, does sound change going around curves ?
Sep 03, 2012 | Ford Cars & Trucks
My 2001 ford escape has developed a humming sound coming from the front tires. It seems to quieten when I steer left. The bearings seem tight.
Most likely a wheel bearing good possibility it is the right one if it gets a little worse when you turn to the right then its probably the right side wheel bearing, they tend to get louder under load. Also slight chance it could be a bad tire.Howie
Apr 21, 2012 | 2001 Ford Escape
Bent tire rod
that person is correct. remove the wheel and look at the tie rods. this vehicle uses a rack and pinion system so look at the rod connecting the rack to the outer tie rod. you will more than likely endup replacing the inner tie rod. then take it to an alignment shop and get it aligned.
Jan 26, 2010 | 2002 Chevrolet Impala
2006 Pontiac G6 front wheel vibration
sounds like your front end is worn out and yes tie rod ends are a common source of this problem along with out of balance tires and seperated tire cords, any tire store will inspect your car for free and give you an estimate to repair.
Sep 18, 2009 | 2006 Pontiac G6
Won't turn right
Had this on my riding mower. The steering rod going to the wheels from the steering assembly was bent. Take it off and straighten it and re-install.
Aug 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The truck vibrates when turning
You could have a bad wheel bearing or out of balance front tire. Without the trailer if you go on a curve the outside tire spins slightly faster than the inside. If you notice more vibration going left, then the right tire is the outside tire.
Jul 01, 2009 | 2001 Ford F250 Super Duty Super Cab
S430 Mercedes - Front end shaking at 55+
It sounds like you have either a broken steel belt in your tire or a worn out idler arm in your steering assembly. Other causes may be a bent wheel, a flat spot on the tire or worst case your brake rotor / wheel hub may be loose. If the rotor / wheel hub is loose you may have severly damaged wheel bearings. Good luck...
May 03, 2009 | Mercedes-Benz S-Class Cars & Trucks
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
