60 inch samsung projection tv occassionally outlines the objects in pink and green.
  • 3,459 Answers
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Sep 06, 2009
I also have one of thos RCA 52 inch tvs and i am having a problem with a double screen like the outline of objects on tv is not centered so it looks like two people and the color is a green and a red...
You most likely have bad convergence IC chips. These chips are located on two large metal heat sinks on the circuit board. They are not very expensive ($60-75 for the pair) but replacing them requires de-soldering the old ones from the board and soldering in new ones. If you have some soldering  experience with electronics It may be a repair you'd like to try. A shop will want $300 and up to do this job. If you'd like further advice on this post back here and I can assist you.
Dec 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture with green and pink outline
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 21, 2009 | Sony KP-46WT500 46" Rear Projection...
Pink/green bar at bottom of picture
phillips are known for dry joints so i would check this first ,if you are good with a soldering iron.
visually inspect each pcb for poor solder connections and solder any bad ones that you find.
this should do the trick.
Aug 18, 2009 | Philips 60PP9202 60" Rear Projection...
Hitachi 61" TV-objects on screen have yellow shadowing
The convergence circuit of the TV is causing this. You will need to have your convergence output ICs replaced. Expect to spend $350-450 to have this issue fixed.
michtech
Feb 12, 2009 | Hitachi 60UX58B 60" Rear Projection...
3 d green and pink
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2009 | Samsung HCM422W 42" Rear Projection...
Hitachi 60SX8B9K
Classis convergence failure - goto www.TvRepairKits.com to get a kit to fix this yourself
May 24, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Need tv help
The sympton for contaminated CRT coolant is objects having a halo effect on the effected CRT color. The Blue and green are the CRTs most often contaminated. But to answer the question changing coolant does help. You can look into the crt with it turned on to see if the coolant is congealed. Just be carteful not to touch any components as you look into the CRT lens.
Feb 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Samsung hl-p6163w
ussally when u get coloerd outlined this idicates ether a convergence or a focuse problem.. the green convergence has become shifted. not lineing up with red and blue.. this also could indicate a green crt problem.. my advice is to get a tech to check it out.. it could be a simple adjustment or a whole new green crt
Nov 16, 2007 | Samsung HCN653W 65" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
367 people viewed this question
Top Televison & Video Experts
