Question about Linksys RangePlus WRT100 Wireless Router
Linksys WRT100 won't connect wirelessly
My Linksys WRT100 works fine wired, but won't establish a wireless connection. Using Vista laptop.
    Sergeant:
  • 336 Answers
Has the adapter in the laptop been enabled?
Ryan Frame
Creative Energy Associates Technical Center
Posted on Sep 05, 2009
Nook E-Reader doesn't connect to WRT100.
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Aug 12, 2011 | Linksys RangePlus WRT100 Wireless Router
My iphone 3gs cannot connect to wifi network at home. i am using linksys wrt100 wireless router.
A wireless client has to support WPS ( wi-fi protected service) function in order to use to add the client to your WPS enabled Wireless Router. check the iphone user manual of your wireless client to see whether it supports the WPS function. If your wireless client does not support the WPS function, you have to configure your wireless client manually so it has the same SSID and wireless security settings, you could also go into the advanced wireless settings and enable WPS ( push and connect ) if your router has this option this is sort of specifically for things like mobile/cellular phones and ipods...hope this helps please vote thanks
Aug 06, 2010 | Linksys RangePlus WRT100 Wireless Router
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
I NEED DRIVE SOFTWARE OF LINKSYS WRT 100 FOR VISTA NOT BOOK
Follow this link
It will take you to the Linksys page for the WRT100 where you can download the driver software. You can either use a wired connection on your laptop, or another pc and save the drivers to a flash drive so you can put them on the laptop. Let me know how you do!
Sep 23, 2009 | Linksys RangePlus WRT100 Wireless Router
Hi I have a wireless router linksys wrt100 and I have 2 laptops (notebooks) and a cpu I also have 3 printers (1 wireless and 2 usb cable printers). I would like to make all wireless is is possible. PS. My...
Option1: Install both USB printers on the desktop computer, and then share them. Your laptops will be able to connect to them, but only when the desktop is turned on.
Option2: Buy a wireless print server, (Available from D-Link, LInksys, HP, etc) and use that to connect your USB printers wirelessly.
If you also want to wirelessly connect the desktop to your network, purchase either a USB, or PCI Wireless NIC for it.
Aug 24, 2009 | Computers & Internet
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Can't connect to internet since purchasing wrt100.
What is your laptop name, model#?
All "wireless" laptops have software that can "scan" for , and "repair" wireless connections. Bottom right corner, do you have a pix [picture] of a monitor ( with what looks like a 'radar' signal coming out ? ) right click mouse and you should see a menu, left mouse click " repair " and follow directions.
that you loose the signal after 3 ft. could suggest that your antenna is not connected right, that the coil ( that makes up the antenna ) is 'opened' or that you did not configure the wireless part of the router.
May 22, 2009 | Linksys RangePlus WRT100 Wireless Router
I am not able to connect my WRT100 wireless router to my laptop, as start the installation process it stops because of static IP address on my laptop. How do i connect? Please help
On your laptop, go to Control Panel > Network Connections > Right-click Wireless Network Connection, Properties > Internet Protocol TCP/IP, Properties > Select Obtain IP Address Automatically and Obtain DNS Server Automatically > Click OK all the way out.
Hope that helps!
Nov 13, 2008 | Linksys RangePlus WRT100 Wireless Router
CAN'T REACH CONTROL PANEL
Connect to the router using a wired connection and use a blank username and "admin" as a password not username.
Oct 27, 2008 | Linksys RangePlus WRT100 Wireless Router
Linksys RangePlus WRT100 Wireless Router Logo
305 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
