Question about HP vs19 (Silver) 19" LCD Monitor
The monitor went totally black turned on the computer and the scren is totally black
  • 74 Answers
Check your cable going to the monitor it may have a pin that is bent or missing
Posted on Sep 05, 2009
Hp modelt60m283 run black scren
Turn off your pc and connect another monitor. If the external monitor works fine then the screen cable is damaged or your laptop's LCD needs replacement.
Jan 20, 2013 | Computers & Internet
Went totally black
Try another monitor(looks like you tried everything else)Or swap monitors with another PC to figure it out.
Jan 02, 2012 | Samsung CLS55 Computers & Internet
I get normal image for 2 seconds then the screen turns black.
you backlight is gone in this monitor, you have two options number one: Replace the scren, Number two: replace the whole thing
Mar 04, 2011 | Dell E198FP 19" LCD Monitor
Dell monitor E156FPb went black
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 29, 2010 | Dell E156FP 15" LCD Monitor
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Screen on Dell Inspiron 2200 went totally dark 2 months after warranty expired. Computer still works when I use cables and hook it to TV - but that is very inconvenient. Help?
that means the scren totally went down, there no way to fix, unless you send back to dell.
but there is a evsy way to use the bottom part that buy a extra LCD screen, so you can still using your laptop and display on the larger LCD screen
Dec 29, 2009 | Dell Inspiron 2200 PC Notebook
The scren is black i cant see any thing
For the second problem, can you get the white writing before Windows kicks in? If so, you will have to hit F8 and start Windows in VGA mode so you can see it. Then you can adjust the graphic display. It could very well be your graphics card is displaying something out of your monitor's range.
Jan 20, 2009 | Optoma PanoView PV755A 15" Flat Panel LCD...
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
Monitor does not work!!
I had identical problem with my. I fix it by purchasing new chips from China (minimum 250pcs)
I have plenty on stock. If you like, I can fix it for you, or send you parts and you can fix it
Sep 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
HP vs19 (Silver) 19" LCD Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
