Question about Akai LCT2701TD Television
THE SCREEN HAS ABOUT FOUR INCHES ON EACH SIDE THAT ARE BLACK AND TE PICTURE IS IN THE MIDDLE. jUST HAD NEW CABLE BOX PUT IN COULD THIS CAUSE THE PROBLEM?
  • 92 Answers
I think it is set to 4:3 rather than 16:9 (aka Widescreen)
It will be shown in both the cable box and the TV's menu. You will have to adjust the settings to suit your TV.
Posted on Sep 05, 2009
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Black screen
If you have a cable box, you just have to reset te cable box. Unplug the cable wire for 30 secoinds and plug that back to the cable box. it should resolve the issue.
Sep 05, 2009 | Televison & Video
Black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Jul 10, 2009 | JVC AV-36150 36" TV
Dog steps on remote and a black screen pops up in the middle of screen but you can see the picture on te outside of the black box. Jvc 32' d-series tv the remote is a jvc rm-c252
Sounds like a closed caption box or a pip box, if not try all the buttons on the remote one by one and lastly try to reset to factory settings if the option is present in menu settings.
Dec 21, 2008 | JVC AV-32S33 32" TV
Black Box in the center of the picture
It's the text screen
remove by using the top left hand
side button on remote.
help me aftervpower off by cable co installer
now have NO sound
but have the sound register graph rising 0 - 50
Mar 28, 2008 | JVC AV-32330 32" TV
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Picture not to full screen
Try connecting just the cable to the TV and bypass the cable box. If you get a full screen and the "ASPECT" button on the remote gives you full operation then either you need to change the output on the cable box to 16:9 output at 1080i resolution (because it sounds like the box is putting out a 4:3 screen size)or in your customer menus on the TV, I believe there is a "AUTO ASPECT" selection? If there is and it is activated then turn hat off. Having DVR won't effect the screen size. It just means the cable box has a hard drive built in to it.
Mar 12, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Televison & Video Logo
41 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
