How do I get the hold timer off??? Model #TCONT802AS32DA
  • 128 Answers
Please more technical information models types are necessary for diagnos
Posted on Sep 13, 2009
How do I clear the timer fuction on my GE profile microwave
hi Donna.
this is all i could find out.
How to clear timer on GE microwave? Clearing the Timer on the Microwave. On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function. Review the Owner's Manual for model specific directions.
Clearing the Timer on the Microwave - Products - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?contentId=16868 Search for: How to clear timer on GE microwave?
or this.On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How to clear the timer fuction on my GE profile microwave Google Search
Nov 26, 2017 | GE Microwave Ovens
I need to know how to set the time on my model RETP RINGGRIP TIMER
To set the time;
Press and hold the TIME button during the time setting procedure. While holding the time button press DAY to set the correct day and HR to set the correct hour (make sure the am/pm is correct) and then MIN to set the correct minutes. (If you hold down the Day/Hr/Min button for more than 2 seconds it will give a fast run-through)
Dec 13, 2012 | Hardware & Accessories
How do you set the times on a Westek TE02 Timer
Thanks for describing timer buttons. And including brand and model number.
I think there are two models, one is 24-hour and other is 7-day.
Copy following link to identify timer, and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westek
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 03, 2012 | Hardware & Accessories
I have a EI500 intermatic timer. It was reset. When ou hold the clock button and press the day button the display goes to all ones, push the hour and displays all 2s, min 3s, it will not do anything but...
There is no repair for defective electronic timer.
Ej500 has 1 year warranty against workmanship defects.
http://www.intermatic.com/customer%20service.aspx
Last step troubleshoot is to replace two LR44 batteries and reset timer.
To reset timer: hold down on-off button and push reset button.
Release reset button.
Keep holding down on-off button until display changes.
Then release on-off button and reprogram timer.
http://waterheatertimer.org/Flipdown.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | Intermatic 7 Day Digital Timer Model...
My wall installed intermatic timer will not shut offf. Either by the program or the manual switch. Help appreciated
Timer model is not known.
Last ditch troubleshoot for ST01C, EJ500, and Ei600 programmable timers is to change battery and then reset timer.
Battery is inside compartment located below programming buttons.
Make note which way battery/batteries come out for easy replacement.
How to reset these timers: Hold down on-off button. Push reset momentarily. Keep holding down on-off until display shows INIT. Release on-off button and 12:00 is flashing. Reprogram timer.
If functionality is not restored, then timer is bad.
ST01C and EJ500 have 1 year limited warranty.
Heavier duty Ei600 is same as ST01C, but has 5-year limited warranty.
Open following link to identify product, and then add a comment for more help if needed.
Aug 01, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Whirlpool dryer model #LER8620PWD serial #MS3630316. I need to hold down the start button and rotate the timed cycle knob for dryer to turn on .
Sounds like you have bad contacts in your timer. By holding the start button and rotating the timer you are just finding a good contact point and allowing timer to send power to the motor. The timer part number is 3979618 and will run you about 90 bucks. hope this helps
_MJ_
Dec 14, 2010 | Whirlpool Dryers
How do you replace the timer in a Kenmore Washer Model 22622?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=41610396bdeaf9d724c8d6b9910df259
Basic Whirlpool / Kenmore washers may use one of two different timers. See the following Whirlpool / Kenmore Service Manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Assuming that you have the metal timer, You'll need to remove the timer knob. The easiest way is to hold the metal shaft that passes through the timer with a thin needle nosed pliers while un-screwing the knob.
Once the knob is off, it's a simple matter to unplug the connectors and remove the bolts holding the timer to the console.
Oct 21, 2010 | Kenmore 22622 Top Load Washer
I have a digital wall timer that allows for settings over multiple days. Trued to reset it (remove a few memorized settings) by pushing 'reset'; but this had no effect. Do I need to press it for a longer...
You posted the question under ST01C timer.
This timer will clear all programs if you hold reset in for a few seconds until the screen starts blinking 12:00. The reset button is a small round button that you push with a paper clip.
The ST01C memory for current day can be cleared by removing battery for a couple minutes, but the day-to-day programming remains forever until timer is reset.
Each timer tends to follow the same pattern as described above when there is a small round reset that is pushed with a paper clip >> push, hold for a few seconds, timer resets.
Other timers have a larger button for Reset ... the timers with larger reset button usually require you to hold the clock button and reset button at the same time ... or some other button besides clock has to be pushed at same time with reset. You can try different combinations of buttons and hold both down for a few seconds.
If you reply to this response with your exact model and brand timer, I can look up the specifics for most timers
Oct 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
DRYER ONLY WORKS BY HOLDING DOWN THE TIMER BUTTON
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Dec 15, 2008 | Dryers
Bulb or Lamp Unit Timer
"paison" was correct and his solution did work for me. Make sure you first select TV on your remote. Now hold down the dvd/vcr button at the bottom of your remote while also holding down the "volume down" button on th front of the TV. Hold until a "Blue Reset Menu" appears on the screen and say the timer has been reset. Noe just follow the on screen instructions.
Dec 28, 2007 | Televison & Video
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
