I press the power turn on button and it immediately turns off
Shuttle83
  • 1139 Answers
SOURCE: tv power wont stay on
Hello All,
The problem that is happening is due to the shutdown circuit activating, which is an indication of excessive current flow. This may indicate a problem in the High Voltage section or in the power supply feed from the HV section. In any case this problem is best dealt with by a trained professional. I would suggest that you take the TV to a qualified TV repair person and have them check it out.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 25, 2008
SOURCE: My camera shuts off immediately after I turn it on.
Have you changed batteries?
Posted on Oct 21, 2008
WiredExtreme
  • 281 Answers
SOURCE: PS3 Console powers on, then off immediately
this is what's known as the yellow light of death. check with sony to see if your unit is still under warranty at this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c42AAD4C5-D9D7-3A33-625E-9DA8C64771EB_k52930EA4-D8DC-F2F8-7A3D-01F2E5C1A8BA
if the unit is no longer under warranty, we'd be glad to fix this for you. all of our repairs come with a 90 day warranty that covers the whole console not just what we fix. we also offer extended warranties for up to 4 years at an additional cost.
you can contact us at: 214-222-5788 or support@wiredextreme.com
www.wiredextreme.com
Posted on Jan 07, 2010
  • 251 Answers
SOURCE: I push the Power button--but usually have to go
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Posted on Jan 10, 2010
SOURCE: when i push power button clicks on immediately
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
Posted on Feb 27, 2010
I have an LG stylo, I got secondhand, I can't use it because it's asking for the original Google account when it was first turned on. How can I bypass it?
Turn the phone off, with the phone off, Press and hold the Volume Down button and the Power button. When the LG logo is displayed release the Power button only then immediately press and hold the Power button again. Release both buttons when the Factory data reset screen displays.
Feb 11, 2016 | LG Cell Phones
TURNS OFF AND ON FROM TIME TO TIME
I got same problem on my nokia e71 after i install kms.9 . I called this problem "failed to start problem". This solution work an my phone . 1.Turn of your phone by taking off the battery and put it on again (do not press the power button) 2.Conect your phone to charger 3.When the screen light turn on and show charging process , press the power button until your phone turn on . Thats it . If this way not working , 1.Turn of your phone by taking off the battery and put it on again 2.Press the power button and immediately conect your phone to charger (before the handshake nokia signature appear) P.S:I recomended you to format your device immediately after you can solve this problem .
Jun 10, 2012 | Nokia E71 Smartphone
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
81 people viewed this question
jasbo
jasbo
