Question about Dishwashers
Water leaks above motor when the machine is turn on.
Kenmore built-in dishwasher model #665 leaks above the motor
  • 135 Answers
The seal around the pump / motor assembly may be bad. The seal can be purchased seperate from the pump.
Posted on Sep 05, 2009
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Jun 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Leak under door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
s7657usut
Mar 07, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Dishwasher does not wash
Stew, Im not really sure what model you have 665, 587, 363 or what. If it's a 665, it sounds like the wash motor is not getting power. Remove the toe panel and look at the start capacitor. See if one of the wires came off during the reinstallation. Should be on the left side of the wash motor. If one of the wires is off, wash motor won't run. If that's ok, check the main harness to the motor. Catriver
Sep 17, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
202 people viewed this question
Top Dishwashers Experts
