Question about Lands Phones
I have an old gpo box for my phone and need a bt master box can i do this ?
    Problem Solver:
  • 5 Answers
DO NOT NO
Posted on Sep 08, 2009
Wiring diagram how to replace old style GPO telephone junction box ?
This is the GPO junction using both BT (left) and old GPO (right). How far back are you going ? This setup assumes you have the British Telecom wiring at some point. Hope this helps...
Oct 03, 2016 | Cars & Trucks
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Why aren't BT master socket extensions working?
Take the two covers off and see if the cables to the other extensions have been disconnected
Mar 31, 2017 | BT Lands Phones
BT 4500 cant answer messages from base only phone help please
Master unit has On/Off answer button. Select option you require.
The extension units do not have a message facility.
Nov 12, 2014 | BT 4500 Cordless Phone - DECT - Satin...
How can i reset without the master password
Hammer? Or you could call BT on 0800 218 2182 and ask them
Jul 25, 2014 | BT Diverse 7450 Cordless Phone - DECT -...
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
Forgot my privious sim password
If you forgot the password ,you need to reset it using the master reset code,You can get the master reset code from the site moz-screenshot-18.pngMobileunlocksolutions.com
reset it,then set new password,You can get the reset code for Nokia DCT and Alcatel phones there,also Blackberry Security unlocking is available there,You cannot retrieve old password,you can reset it Only.Before get the reset code for Nokia DCT phones You can try 0000 or 12345 or 1234 this is default codes if not work means get the master reset code there and reset it.
Oct 25, 2011 | Cell Phones
I can not recive calls or make calls the line is dead I have checked everthing and I can get broardband
I had the same problem when I purchased a 710 for my mother in law. Worked in my house but not hers. The phone does not come with a BT box to phone connection line so that was a clue. Through a process of elimination I discovered that her connection line did not work with the 710, although it was ok with her old phone! I purchased a BT to RJ11 line extension lead from Maplins - all is now ok. I can only assume older connection leads are different than newer ones!
Jan 01, 2011 | British Telecom BT Freestyle 7100 Cordless...
I want to change my old telephone socket for a new one, i have the BT line with a orange and white wires coming in and i have an extension with six wires coming from the box located in place numbered 1 to...
With BT there are only TWO wires, Tip & Ring... these wires simply go daisy chain from socket to socket, they ALL go on 2 & 5 in the socket. ONLY the FIRST socket should have a capacitor, and be the "Master" socket. The "LINE" also goes onto that 2 & 5 in the Master too.
http://www.britishtelephones.com/wiring/socketwiring.htm
Mar 22, 2010 | Cell Phones
Bluetooth Connection
i think you should be much more clear in the information you just give..is it that you can not connect to any devices thru BT or is it that you can not find the BT on your phone.
If you can not find the BT on your phone..have your mobile phone reflash (Firmware).
If you can not find any BT devices when searching on your phone then do a master reset.
May 04, 2008 | Motorola Mobility L6 Cellular Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
