Question about Poulan Pro " Pro" Self Propelled Mower
My 550 series motor won't run except on the prime. I bought the mower a week ago, it ran fine I went to run it again today and the only running I get is off of the prime. wmenkel@cfl.rr.com It's on a poulan pro mower.
  • 40 Answers
One of your fuel lines are bad and it is losing its prime
Posted on Sep 05, 2009
I have a craftsman Briggs & Stratton 550 Silver Series mower that won't idle after being primed. I have tried every solution found online and it still won't idle. Any thoughts?
what is every solution found? does it run at full throttle? if I remember right the 500 series is all or nothing and if it's nothing then I'd say to replace the carburetor. it is running on the prime and once that s gone it dies as the carburetor can't supply fuel enough to keep it running. you can try cleaning it but for about 30 or 40 bucks it's just as easy to replace.
Sep 29, 2013 | Garden
2009 190cc Briggs starts but won't run
Ensure the oil is full. It has an oil low sensor. 30w oil.
Jun 13, 2013 | Toro Garden
Troy-bilt 550 series mower won't start. I've only used it twice.
does it crank over?did you leave the blades on?are you pushing on the brake pedal
May 25, 2012 | Troy Garden
I purchased a 550 series mower last year. It worked great. I used it a week ago and it worked great. Took it out today and it starts right up but won't run for morethan 5 seconds....starts right up...
Hi, remove the bowl off the bottom of the carby and clean it out. My best guess at this stage is that you have water in the bowl. Hope this helps, regards Phil.
May 25, 2011 | Poulan Push Mower
I bought the compressor about two years ago and used it only a few times. It ran fine a few weeks ago but today it will not start. It is as though it is not plugged in even though the outlet works for...
Is it possible that you didn't drain the air out of it after you used it a couple of weeks ago? If the pressure in the tank is somewhere around 100psi, the compressor won't run until it drops lower. If there is no pressure in the tank you might see if you can wiggle the pressure lever that makes the switch move to turn on the motor - it might be stuck.
Aug 04, 2010 | Air Tools & Compressors
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Poulan Pro " Pro" Self Propelled Mower Logo
349 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
