Question about Onkyo TX-SR501 Receiver
Describe your Onkyo TX-SR501 6.1 static in left front speaker I tried a different speaker same problem
  • 1 more comment
  • john749 Sep 05, 2009
    still not working :(
    i have a onkyo sr501 reciever the left front speaker has a bunch of static i switched speakers same problem
    still happening the right front speaker is fine. when i run the reciever speaker test all the speaker are fine except the left front.
I have exactly the same problem.
Switched speakers - always comes out of left channel Switched inputs - always / still comes out of left channel Switched input type - HDMI-back to Digital Optical Input (both inputs Opt 1 and opt 2) has same problem
Then I tried Analog in/Analog out to second amplifier (an Arcam Alpha 1 1985 vintage) and the pass through worked fine
So I have a problem in the 501 for sure, but not sure if it's worth fixing when I can have a r08 shipped to my door for less than $300 all in. and am I OK with a lightly used 8 year old (at most) Onkyo 501 failing on me like this?
Posted on Jul 27, 2010
  • 4,234 Answers
Without actually hearing the static, I can't be 100% sure, but you could have digital noise. Try turning off any surround processing and see if the noise goes away. That should bypass any digital processing.
Please update this with the results. That will determine the next step.
Thanks,
Dan
Posted on Sep 05, 2009
  • ABRsvcs Sep 05, 2009
    Thanks for the update. One of three things will be required to repair this unit:
    1) Replace the DSP IC on the DSP board.
    2) Replace the entire DSP board.
    3) Track down a possible defective transistor (or pair) in the front end for the left speaker channel.
    The root cause here is likely to be a defective DSP IC. This is the portion that processes all surround sound information. It sounds like the result is a distorted channel. It remains to be seen whether the digital stream is faulty or if the channel has a problem in the early amp stages. Without actually seeing the unit and looking at signals on the scope, I can't tell which.
    This unit will need to see a service center. It is a decent unit and is worth the repair cost. If the center tries to replace the DSP board in its entirety, it will be expensive. Request that the board be repaired if possible.
    Please keep us posted.
    Thanks,
    Dan
  • 3,741 Answers
Click this link directly for setup http://www.ch.onkyo.com/files.download/tx-sr501_manual_e.pdf also if you require manual you can click this link http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/TX-SR501E-_E
check out.and set the speakers as per the manual. thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
VERY LOW VOLUME FROM SORROUND SPEEKERs
some surround sounds do not put out loud sounds except from the front speakers only. Try using different inputs to see if it makes a difference.
Jun 17, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Mar 08, 2009 | Onkyo TX-SR705 Receiver
Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Mar 15, 2008 | Onkyo TX-SV545 Receiver
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
Onkyo TX-SR501 Receiver Logo
259 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
