Question about Olympus Stylus 1010 Digital Camera
Lense won't retract
When I turn my camera on and it's on auto the lense immediately zooms out and will not retract. There is an orange lightening symbol that continuously flashes.
    Brigadier General:
  • 4,090 Answers
Also try this, as it is often nothing to do with batteries! IUt is to do with dust and dirt in the lens mechanism. so..dont laugh!
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 180 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate my help++++Thanks for using FIXYA
Posted on Oct 31, 2009
    President:
  • 2,761 Answers
If you've recently dropped the camera you may have lens damage that will require professional repair. But if the lens is OK, your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. It's not a cure-all. but this cleaning cures the problem about 90% of the time. I hope it works for you.
Posted on Sep 19, 2009
Sigma 170 500 lense not retracting lower than 300mm
One of the plastic stop paws is broken.
Jan 07, 2014 | Cameras
System error focus
you hve probably damaged the lens unit. impact while the unit was extended? the auto power off will retract the lens thus damaging the little plastic gears in the lens unit. you may need to replace the lens unit
Dec 18, 2013 | Panasonic Lumix Dmc-fh1 12 1 Mp Digital...
Can you use the twist-barrell zoom lens on a Sony DSLR camera (or any DSLR) when the camera is set to auto-focus? I've been told that this damages the gears in the lens if you do. Thanks for your help.
You can zoom completely independent of the focus.
Some lenses immediately override the autofocus when it senses you turning the manual focus ring. Other lenses don't, and you can damage the lens by forcing it. It depends on the lens, so you'll have to consult the documentation for the specific lens.
Jul 06, 2011 | Sony Alpha DSLR-A200K Digital Camera
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Fuji finepix a600
If the camera was on when it was dropped you probably jamed the lense coil. The lense coil is what helps the camera smoothly pull in the lense and back out. Now, just to specify, what exactly are you having a problem with? Will the actual lense not go back into the camera when you turn it off; or can you not get your camera off zoom?
Let me know~
Olivia
Oct 30, 2008 | Fuji FinePix A600 Digital Camera
Camera refuses to zoom out
I had a similar problem. The lense extended when I turned the camera on and immediately retracted and turned off by itself. I pulled the memory card and then reinserted/reseated it. It appears to have fixed my problem.
Apr 29, 2008 | Canon PowerShot A95 Digital Camera
Olympus Stylus 1010 Digital Camera Logo
458 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
