DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Problem for DISH Network DVR-625 DTV Receiver / 100-Hours Video...
Dish 625 DVR recorder won't play recorded shows.
By mikej10x on Sep 05, 2009
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Solution #1
posted on Sep 05, 2009
Somewhat Helpful)
denz_maveric
Rank: Wiz
Rating: 84%, 123 votes
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Was this helpful?
Yes
No
Popular Solutions for DISH Network DVR-625 DTV
Questions and Unsolved Problems for DISH Network DVR-625 DTV
Do you recommend DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder?
Answer
Answer
I have been having DISH DVR problems lately. The most recent is my recorded programs list is not... (More)
Answer
Unable to record or skip backr skip forward or skip back. I have tried the power switch bit several... (More)
Answer
I need to program my URC-4220 ONE FOR ALL remote to operate my new dual dishnetwork dual dvr for tv... (More)
Answer
Recently, my (replaced twice) DISH 625 has started skipping to the end of a show that was recorded... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Receivers... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
