Question about Dryers
I need to know how to remove a thermal light
My Frigidaire dryer needs a new thermal lighter. I need to know how to remove the old one.
  • yadayada
    yadayada May 11, 2010
    thermal light? no such part that I am aware of, what does it do?
  • 612 Answers
Thermal lighter? I'll need a complete model number so I can tell how your model is built
Posted on Sep 05, 2009
  • 40 Answers
Take a 7/16 wrench, and where it is attached at the gas valve, unscrew it and then follow it to pilot light and it should just pull out of the hole that holds it to the pilot light
Frigidaire Affinity gas dryer problem
I would bet you need new door lock switch
Jul 13, 2017 | Frigidaire Dryers
Hi I have a dryer model # GLEQ215ES1 The dryer will run proper if I turn the heat off, but when heat is on it only runs for about 10 minutes and shuts off and all the lights on the right side blink.. Any...
It sounds like the hi-limit thermostat. For your dryer that would be Frigidaire part number 5303281113 shown below. The part is located behind the drum. You will need to take the back off of the unit to access the part. Sears carries the part.
  1. Take the back cover off of the dryer
  2. locate the part
  3. unplug one of the two wires from the old part
  4. plug that wire into the same post on the new part
  5. unplug the remaining wire from the old part
  6. plug the other wire into the new part
  7. unfasten and remove the old thermostat (with no wires)
  8. fasten the new part (with wires) into the old parts place
  9. run the dryer to see if the fix works
  10. replace the back cover on the dryer.
Steps 3 through 6 above insures that you get the two wires installed correctly. ddmagee57.jpg
Apr 27, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
Frigidaire front load dryer won't turn on at all
check the main power and terminal block make sure there is power and no problems with the terminal block.
also a bad thermal fuse can cause a problem with the power check the thermal fuse and make sure they have continuity.the last thing to look at is the main control board these can cost up 150.00 dollars depending on where you get it.Bottm line yes i would say it is worth fixing
Jul 27, 2010 | Frigidaire Electric Dryer
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Dryer quit heating
Hello Friend, Your problem is very simple to fix. I'm assuming that you have a standsrd model Whilpool dryer. You didn't specify if you have a gas or electric model so I have given you the basic instruction to repair both models.
IF GAS DRYER FOLLOW THESE STEPS: You're dryer needs a thermal fuse and or gas valve coils, and maybe an igniter all three are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new, if it doesn't then you will need to check the igniter. The igniter is attached to the end of the burner assymbly by one screw and a simple two wire plug. Inspect for breakage, and replace if needed.
IF ELECTRIC DRYER FOLLOW THESE STEPS: Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new.
Happy to help, Tim.
Jun 27, 2009 | Whirlpool WGD5300S Dryer
Electric dryer not heating...works fine, but no heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 04, 2009 | Roper RGS7646KQ Gas Dryer
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FEQ332ESO electric dryer: No Heat
If im looking at my papers right, this unit is a stacker, correct? The element is directly behind the drum on Frigidaire units. You can I believe remove the top, then remove the front cover by removing two screws on the inside the hold it to the cabinet. I believe the element and thermal fuse should be able to be tested from the top. After you remove the top, the wiring should be on the right rear side. The thermal fuse is round, and has two wires going to it. It can be located on the element housing itself, or on the rear bulkhead. To test this fuse, you will need a meter that reads continuity (ohms). Just attach the leads and see if you get a reading (be sure to remove one of the wires). The element wiring should also be in the element housing. You will see the wires coming off the top (all by themselves, not attached to a thermostat). Testing will be the same way. If you have to replace the element you will need some help more than likely. The drums in Frigidaires pop out. You will have to remove the belt, then (with towels wrapped around your hands to keep all your skin) lift the rear of the drum up to pop it out of the bearing holder (like a ball joint). Then you just unscrew the element, and replace. Its not uncommon anymore for anything to break on these new units, in fact, 90% of my business is in warranty call, usually within 3 months of purchase. Sorry, but would rather be truthful than blow smoke. Good luck, and let me know if there is any other questions you may have.
Feb 03, 2008 | Dryers
Dryer suddenly stopped - F&P ED56 Autosensing Dryer
what is the make/model of your dryer and does it have an electronic display? different solutions apply to different models thank you
Sep 09, 2007 | GE DVL223GB Gas Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
