Question about Magellan GPS
First, I plugged in the roadmate and it dowsn't say it is charging. It's just working and taking me thru the list of directions. How do I know if it is charging? I've never used it before.
  • franruby411 Sep 05, 2009
    Magellan RoadMate 1412
    President:
  • 1,111 Answers
With the unit unplugged, but turned on, go to user options/system setting and there will be a battery meter at the bottom. if its fully green the battery is fully charged. if its only partially green, plug in the charger and see if the green moves toward the right. it should continue to do that untill the battery is fully charged.
if the green indicator does not move to the right when the battery is low and plugged in to the charger, the unit is not charging.
its common on this model and many others for the usb port (charging jack) to go bad if its not charging.
bill
Posted on Sep 14, 2009
  • 426 Answers
I need to know what your model is to be able to tell you how to solve this problem. Get back to me and we can go from there
Posted on Sep 05, 2009
  • Xander  Kravitz
    Xander Kravitz Sep 06, 2009
    "If the power indicator light on the vehicle power cable connector is on, power is being supplied to the
    Magellan RoadMate." taken right out of the factory manual. hope this helps, i had to search to find it but it was there.
  • Xander  Kravitz
    Xander Kravitz Sep 07, 2009
    I am wondering why you listed my answer as somewhat helpful, You asked how to know when the system is charging, I told you exactly how to know when it is charging. In my reasoning that is a spot on answer, not somewhat? What can i do to better serve you?
Describe your how to charge my magellan roadmate 5045...does it have to be on?
hi crystaldehar
no, it doesnt have to be on, but does take a few hours to charge...magellan recommends using the car charger or the ac adapter to initially charge it for atleast two hours...if you use the car charger, there should be a light on the charger to tell you its working and charging your unit (provided theres nothing wrong with it)
you should also have gotten a usb cable with your unit, it will (should) also charged while hooked to your PC via the usb cable.
let me know if you need further help...HERE is your manual
bill
Dec 24, 2010 | Magellan Roadmate 5045 GPS 5inch Screen...
The gps is a magellan RoadMate 2000. It does not get a satellite signal and it has been reset and left outside to try and get a signal and still will not get one.This just started about a week ago. Thank...
hi foxylady0415,
try and run the update and make sure its fully charged and try again...you can get the update HERE
download and follow the directions exactly, and make sure the batery is either fully charged or the gps is plugged in to a good charger.
Bill
Standing Member of G.O.T.
Oct 21, 2010 | Magellan RoadMate 2000 GPS Receiver
Can I charge my Magellan roadmate with USB cable connected to the computer?
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Apr 18, 2010 | Magellan RoadMate 1340 GPS Receiver
Can I charge my magellan roadmate 1340 using the USB?
Should be able to so long as it is set up for it, plug it in and see if the power light comes on, then leave it for an hour, at that time see if you can turn the unit on. You will at this point have your answer to your question. Make sure the computer is on though. (i know, but i didn't put that in one time and i got a nasty message from somebody, so now i put it in.)
Mar 11, 2010 | Magellan RoadMate 1340 GPS Receiver
Roadmate 700 will not power up
Direct to the nearest Magellan Agent. If you have fully charged the unit and you know the batteries are OK!
If its under warranty take the warranty card with you
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Magellan RoadMate 700 GPS Receiver
My magellan roadmate 1212 will not stay on unless plugged into
if its not charging the battery, the meter will say full even though the battery is dead..its a very common problem with alot of gps with the usb as a charging port. my solution is if this is still under warranty, i would send it back to magellan or where ever you bought it, because sooner or later the usb port is going to totally fail and wont even start up if plugged in and your going to be left with an expensive paper weight.
Jul 29, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Worked for a year, now says not charged when plugged in
Try to use a wall adapter and charge it for 4 hrs before you plug it in the car because it is much better if you use a wall adapter it gives more power.
Jun 09, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Battery question
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Megellan RoadMate 300
You can find it here: http://magellan.cachefly.net/manuals/MRM_300na_en.pdf
You may also want to know that there is a MAJOR firmware update avaiable for your device.. It looks like it would make your GPS a lot faster and more accurate. You may want to take care of that update too while you're working on your device. The update can be found here: http://www.magellangps.com/support/notes.asp?supportID=288
Let me know if that helps!
Regards,
Steve
Sep 01, 2008 | Magellan RoadMate 300 GPS Receiver
GPS Logo
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
