Question about GE Washing Machines
Should there be water in the machine when not in use
  • GE Master
  • 2,005 Answers
No the pump should pump it all out
Posted on Sep 05, 2009
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
I have dwf-170 mp washing machine, the machine does not fill with water.
that is not the water pump but the inlet valves are you sure the water is turned on behind the machine
Mar 28, 2016 | Washing Machines
Lack of hot water
washing machines are a hgigh demand water usage sytem anyway..I would use the regular water heater with the washer as it holds 40 gallons and most washers pump in a minimum 20 gallonson the low side..
Mar 08, 2014 | LG WM0642H
The water stopped coming into the machine?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
Water isnt going into the machine
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Dec 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Hot water is a small trickle into the machine - warm water gives you a bit more water coming into the machine & cold water has a moderate bit of water coming into the machine. We have extremely hard...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 01, 2010 | Frigidaire FWS833A Top Load Washer
Machine does not take water. the water does not come in to the machine. I think it can be the water pump.
Before breaking into your machine, shut off your water inlet valve(s) to the machine. Remove your water inlet hoses from the machine and aim them into the wash tub or a bucket. Check water flow through hoses. Debris in water system can clog up the screens on your water hoses.
Aug 02, 2009 | Washing Machines
Machine not filling with hot water
First check the filters in the inlet hose and hot water pressure. Sounds to me like the hot water valve is faulty. Test the w/machine on a hot water cycle, if you hear a noise and its not filling it up with water,its a faulty hot water valve. Air pressure?? change the water valve and remember it has a little rubber boot on the old water valve, transfer this to the new valve,or go into option adjustment mode and change you wash temperature settings.
Aug 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Feb 07, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
12 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
