Question about Edirol UA-4FX External Sound System
No sound either
Every feedbacks tend to say the PC is receiving sound but nothing is coming out of the speakers... why?
  • funguss Sep 05, 2009
    I have no such option in the F12 setup menu...
    no every driver seems optimal, I re installed all of them.
    The devices seems to be set correctly in the sound control panel (i have vista) and the test are ok.
    Cubase receives sound and the device is set correctly.
    But the speaker doesn't want to play that input! They'll play anything but what's coming from that UA-4FX.
    even when I record with window recorder I can't hear it when I play, but when i open the saved file to listen to it I hear the guitar.
  • 733 Answers
Do the speakers have power, if so, is the integrated audio turned on(During start-up hit "F12-setup" right before boot up. Your pc might have this option, if so turn it on, if it's on then you may have an issue with your audio drivers. go to start/control pannel/performance and maintanace/system/hardware/device manager.....now check to see if you have any yellow exclamation marks on the audio devices, if so you need to re-install drivers...if everything checks out ok here, then your soundcard is bad. good luck
Posted on Sep 05, 2009
  • Pablo Gonzalez Sep 05, 2009
    do the speakers have power, if so, is the integrated audio turned on(During start-up hit "F12-setup" right before boot up. Your pc might have this option, if so turn it on, if it's on then you may have an issue with your audio drivers. go to start/control pannel/performance and maintanace/system/hardware/device manager.....now check to see if you have any yellow exclamation marks on the audio devices, if so you need to re-install drivers...if everything checks out ok here, then your soundcard is bad. good luck
High frequency noise form my 7.1 surround sound system
Is the microphone live? If so, what you're getting is called "acoustic feedback". Any room sound gets in the mic, gets amplified, comes out the speakers, and then gets picked up by the mic again. Louder and louder until you get to the maximum your system can do.
The solution is to turn it down. . . until it stops.
May 13, 2015 | Acesonic HKR-710 340-Watt 7.1 Surround...
Ext in problem
if you are using the ext in then it has to be something wrong with the setup from the pc. The receiver does nothing to the ext in input except amplify it and put it out to the speakers.
Jan 14, 2014 | Denon AVR-1907 Receiver
Distorted, cracked sound coming through to the speakers
is it possible your new reciever has a built in phono pre-amp?
If so, you need to switch off the pre-amp inside the turntable (lift up the rubber matt, and rotate the plate untill you see the switch at the back)
Try again now?
Feb 12, 2010 | Aiwa PX-E860 Turntable
No sound from my ht r520 6.1 model
I have the same problem. No sound on the speakers or on the headphones.
Aug 24, 2009 | Onkyo HTR500 Receiver
System turns on but only hear feedback fomr speakser no sound
do the headphones work?that means the pre amp is working.
the speaker protection is maybe activated from shorted wires on the back,there should be a click 5 to 7 seconds after turning it on.
that is the relay that connects the speakers.check the speaker a and b switch. people are not aware of this,but alot of amplifiers ADD the a and b speakers,to prevent too low an impedance from parallel wiring.unless there is 4 speakers,no sound.
May 22, 2009 | Pioneer VSX-D409
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
May 04, 2009 | Pioneer Audio Players & Recorders
Sound coming out of wrong speakers
I know nothing about your model but the very first thing that I would do is to pull the power cord from the wall outlet for at least 10 minutes and then plug it back in. This may reset everything.
Apr 15, 2017 | Pioneer VSX-D608 Receiver
ONKYO TX-DS939 (sound and heat/fan issues)
This sounds like the amp is seeing too small an impedence load. In other words, the amp is expecting to see an 8ohm load and is being presented a 4 or 2 ohm load. This will force the amp to work really hard and generate excessive heat. Does the amp generate sound at all? ever? If not, then you probable have a situation with high frequency oscuillations that you can not hear. This means that the amp is sending out a lot of power to the speakers that the crossovers are shunting to ground. Without seeing the output of the amp with a scope, I can not confirm this. This is not a problem that will be solved remotely. Bring the unit to a shop and request that the output be examined using a scope to check the waveforms. I suspect that a bad feedback look internally is causing the generation of the high frequency signals.
Keep us posted.
Dan
Oct 29, 2008 | Onkyo TX-DS939 Receiver
Feedback noise in speakers and Woofer.
hi wfj1310,
that feedback comes from the distance between the mic and the speakers only. Low the record level from the mic and make the distance bigger.
it makes feedback with any speaker, not only with woofer :-/
complements
Oct 25, 2007 | Audio Players & Recorders
Edirol UA-4FX External Sound System Logo
89 people viewed this question
Top Edirol Computers & Internet Experts
David
David
Ben Armstrong
Iqbal Husain
Iqbal Husain
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
