Question about GE Dryers
Turn start dial and get buzz, but dryer does not start have checked belt and fine
    President:
  • 1,776 Answers
Check for a blown thermal fuse. It is about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Posted on Sep 05, 2009
So we have a Maytag DE308 and for some reason whenever we try to push the dial in to turn it on, it buzzes but will not start. Any ideas as to what this could be?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 28, 2010 | Dryers
I have a maytag 2200 dryer and it just buzzes and the motor does not turn. The problem is intermittent, it will work fine for a while then just buzzed again until something kicks out. I have disconnected...
In your case it sounds like the motor is going bad...
heatman101
Sep 25, 2010 | Dryers
Frigidaire Model # GLER341AS2 does not start. When turning the "ON" switch a buzzing sound happens, nothing else. I have unplugged, flipped the circuit and re-plugged in. Did not work. I have turned...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 08, 2010 | Frigidaire Dryers
Dryer Does Not Tumble When Pressing Start
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
May 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Wont turn on, just buzzing sound
Sounds like a bad motor for you...
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 | Dryers
Drum will not turn
hello check to see if he belt as not snap if ok could be brushes on the motor good luck
shaun
Jul 28, 2009 | Whirlpool LEQ9858L Electric Dryer
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
