Question about PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive
Imation USB not reading in My Computer
My new 4gb Imation USB is not reading on any computer with Windows, it shows in device manager and dings when i inserted into the port but cannot open or recover any files. My computer cannot detect anything. Code 47 troubleshooting did nothing. Please help, my files are important, I have got further than the computer shop though and they charged me $50 just to look!
  • 928 Answers
Insert the device and restart the computer. Does it shows a "removable disk" icon in My computer? If it does, go to the properties and click unblock, may it's block. If that doesn't work, then just reformat.
Posted on Sep 05, 2009
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
My usb imation 4GB PB1 is not format
1.) Plug it into a computer.
2.) On the computer, go to Start, then Control Panel.
3.) When the Control Panel opens, go to Administrative Tools, then Computer Management.
4.) On the left-side panel of the new window, click on Disk Management. It will take a moment to load something in the middle panel.
5.) In the bottom portion of the middle panel, scroll down until you find the Defender. Right-click on it, then select "Format" from the list.
6.) A small window will appear. Where it says "Volume label," type in what you would like to name the device. For the file system, select "NTFS" from the pull-down menu. Leave the "Allocation unit size" as default. Then click the "OK" button.
7.) It will take a moment, but then it should be formatted for you.
Oct 14, 2012 | Imation 4GB DEFENDER F100 FLASH DRIVE USB ...
My imation flash drive nano 32 gb was partition public is 4gb and private is 28gb, how can i delete the partition so that it will return to its original size of 32gb.. i partition it using the imation...
click start click on computer then right click on your imation usb drive select format
this will return it the original size but it will remove any data on it
you could try to expand the partition
click start control panel administration tools computer management disk management you should see your usb drive right click in the small partition see what options are available a delete option might be there im not sure on imation software (partition magic has this option)
hope it helps
Aug 13, 2011 | Computers & Internet
I have an imation 4GB nano usb, which just stopped working and i cannot format it because it's write protected.
If you plug it in and it shows up, right click on it from "my computer" (windows) go to properties and you should be able to uncheck the "read only" box. click apply and you should be able to format it... I think.
Jan 08, 2011 | Computers & Internet
4G Usb Imation Pen Drive has stopped being picked by any PC
there are two reason for ur problem
a) when windows XP fails to allocate a drive letter to your portable drive(pen drive)
b)some other technical faults in your pendrive
to solve ur problem follow these steps below
Right click on My computer icon->Select manage->Select Computer management->Select Disk Management under the storage section
-> In the right side will show you all of the current drives and partitions on your drive.
If you don’t know which is your pendrive, don’t worry, just find the drive you are looking for in the graphs at the bottom. They are usually named Disk 0, Disk 1, CD-ROM, CD-ROM1, etc.
If you’re looking for a USB flash drive, you’ll see the word “Removable” underneath Disk X -> Now right click on the icon -> Select Change drive letter and paths -> Assign a new Drive letter-> click Ok.
Now your pen drive will be detected in the computer.
there is an another way to solve ur problem
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, i think this should solve the problem.
May 12, 2010 | Computers & Internet
My daughter has a kingston 4GB DTI Data traveler. When she tries to put mp3 or any type of files it gives her a message that the file path can not be found and can not copy anything to the jump drive..She...
insert your pen drive again and see whether your system recognize it. go to my computer and right click on the pendrive icon and select format , then clink ok.
Jun 19, 2008 | Computers & Internet
Imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Jun 06, 2008 | Electronics - Others
PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive Logo
1,052 people viewed this question
Top PQI Computers & Internet Experts
Arora Singh
Arora Singh
William Alequin
Are you a PQI Computer and Internet Expert? Answer questions, earn points and help others
