Question about Medion md40298 Notebook
Medion laptop shuts down itself
My laptop computer shuts down itself within 5 sec when I turn it on. My Battery is not good I know that but AC cable is connected, still not coming on. what could be the prab;em, any suggestions appreciated.
  • 1 more comment
  • lizzierich Jan 17, 2008
    My medion laptop comes on for about 5 seconds then turns itself off agggghhhh
  • Anonymous Mar 28, 2009
    I have the sme problem with my medion. Medion tech says it is a motherboard problem and therefore I need to replace it.
    Did you find another solution?
  • vex338 Apr 29, 2009
    I have the Same problem With my medion notebook mim2310
    it is a nightmare , because i know my battray is Fine , but i took it into Pc world , and they have told me that my motherboard is Cracked , and i need to replace it , which is immpossable because you can't buy them anymore
  • 383 Answers
HI there, I wonder if someone could help me with the problem I am having with a Medion E1210 netbook. (mini laptop) When it is running on battery, it shuts itself down after, between 2 and 30 mins, even...
did you try the ac adapter those go bad too, the amount of voltage coming out of the adapter is not higher than the batteries out put voltage, then the battery wont charge
try the ac adapter
Oct 09, 2010 | Medion md40298 Notebook
I have a Dell Latitude D600 power problem. When the AC charger is connected the unit will power down by itself within 10 secs the most. If no AC charger connected, the unit is fine.
Please try removing the battery then attached the ac adapter and see if the same thing happens. It is possible that the AC adapter is faulty already if it doesn't isolate the issue. Please let me know if the result. Thank you and regards.
Sep 25, 2010 | Dell Latitude D600 Notebook
3 weeks ago My Laptop HP Pavillion Entertainment system DV9500 shut off while I was using it and now it doesn't even power on. I purchased a new power supply thinking that was the problem but still can't...
unplug the ac adapter from the laptop and remove the battery
press the power button for about 5-10 secs
while the battery is out, plug in the ac and turn on the computer if still doesnt turn on
use a known good adapter and plug it in if it still doesnt work then motherboard needs to be replaced
hope this help
Sep 07, 2010 | HP Computers & Internet
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Compaq nx5000 with new battery and new power
Try pressing the CAPS LOCK. If CAPS LOCK is responding then it is surely your inverter.
It is a known problem with the nx5000 series laptop.
The FAN switches off because Intel SpeedStep which is absolutely normal.
I faced and solved at least 6 - 7 such problems on different nx5000 laptops
If CAPS LOCK is not responding then its your motherboard.
Good Luck and Regards
Nov 25, 2009 | HP Compaq nx5000 Notebook
MEDION MD96640 - plugged in, not charging
There is a possibility that the battery is defective.
Turn the laptop off and remove the battery and AC power. Clean the brass contacts on the battery and the laptop.
Plug in AC power only, boot the laptop up without the battery and go into the BIOS and set the BIOS to default settings. Save the changes and let the laptop boot into Windows. Once in Windows power down the laptop again and remove the AC power.
Reinsert the battery and AC power and boot the laptop up. See if that has helped.
Good luck.
Sep 21, 2009 | Computers & Internet
HP 530 Notebook will shut off by its self and when you restart it and will show you that windows was not shut down properly. Could it need a new battery?
The problem lies with the power supply system either in the power adopter or inside the laptop. When AC power is plugged in, the system shows that the battery is being charged (Yellow Light Indicator switches ON) but practically niether the battery is usually being charged nor the computer is being run by the AC power. Its a little bit of energy left in the battery that keeps running you computer for some time and as soon as the battery is discharged the note book shuts down by itself.
However, the Taskbar battery indicator gives the correct picture of battery charge and the charging process. Better rely on that.
Its a hardware problem pertaining to power supply and charging system and doesn't have to do any thing with Mother board, RAM, Hard disks or other hardware installed in the PC.
Do tell the above details to a repair workshop man to rectify the problem.... Best of Luch
Aug 18, 2009 | HP 530 Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
While in BIOS command mode, turned of - not possible to start anymore
Hi Marc, Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps.
May 06, 2007 | IBM ThinkPad A22m 2628 Notebook
Medion md40298 Notebook Logo
1,743 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
