Question about Refrigerators
Refrigerator side is getting colder than setting. Has frozen water filter water
  • 4,059 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Sep 05, 2009
My Refrigerator makes ice but doesn't dispense water
The water reservoir is probably frozen. Remove the drawer second from the bottom and place a hair dryer on the shelf blowing on the coil of water line referred to as the water tank/reservoir. Let it blow hot air on it for 10 to 15 minutes. Try the water dispense. If the water flow is restored, set the fresh food section one setting COLDER to increase air circulation. Set the freezer to one setting to one setting warmer to circulate air that is a bit warmer. This corrects 90% of the issues related to water dispense.
The other 10% is normally the fault of the water valve.
Here is the water valve to order in case it is faulty.
Regards,
Richard Roth
http://appliancecafe.com
Oct 31, 2012 | GE Refrigerators
We have plenty of water and pressure coming to the refrigerator from the house, but when we try the in-door water dispenser, the water comes out at a slow trickle. Ice is not making. We installed a new...
whirlpool has had frozen waterline issues whats temp in refrigerator and freezer make sure refrigerator no colder that 37 degrees and freezer th 6 degrees
Jan 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Jul 01, 2010 | Frigidaire FRS3R5EMB Side by Side...
WE GET NO WATER OUT THE DOOR AND THE LIGHT DOES NOT WORK. THE ICE DISPENSER WORKS FINE.
It sound like the filter is frozen, you will need to remove the filter for about an hour or two and let it set at room temp and then replace it and see if this is the problem. If the filter have frozen it is usually cause by holding the refrigerator open or several trip to the refrigerator throughtout the day.
Apr 16, 2010 | KitchenAid KSCS25FKSS Side by Side...
Please help fix my fridge
mine did that and it was due to a frozen water line that blew out the thermostat. See if the water line is frozen first. It was located on my refrigerator behind the crisper drawers. the tech had me use a hair dryer to thaw out the line
Dec 10, 2008 | Samsung RS2630SH Side by Side Refrigerator
Jenn-Air side by side won't give water
hi thanks for the question yes the small tube that enters the ice maker can freeze up stopping the water flow check this thanks the appliance doc
Sep 16, 2008 | Jenn-Air JCB2280HES Side by Side...
I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
May 05, 2008 | LG LRSC-26922 Side by Side Refrigerator
Food in the freezer of 52603 is too cold/frozen.
This would usually indicate that some refrigerant gas has leaked out - the effect at certain percentages is to allow the gas to expand too much when it first enters an evaporator (the plate in the freezer that gets cold), thus making it much colder than the thermostat is set too. due to environmental laws you cannot top this up yourself, it must be done by a qualified fridge guy. get him to check for leaks as well, usually they can be fixed if there is one, but a tiny amount of refrigerant can leak out over time with no actual major leak. Try first defrosting completely - occasionally ice crystals can form inside the refrigerant system which may be causing the problem, once defrosted, this water should be dealt with by the filter/drier. Probably still needs refrigerant gas, but is worth trying. once the gas is topped up then ask the guy to check that the freezer thermostat is working correctly - it could possibly be faulty, no way to tell easily without just replacing it or topping up the refrigerant gas first. Hope this helps, please post again if not :)
Mar 26, 2007 | Kenmore 52673 Side by Side Refrigerator
No Ice
I've got one, and the bracket in the back that connects the motor to the long screw-crank in the floor of the ice tray broke in half, so no ice was getting pushed to the door to come out the front. Putting in a new bracket started ice coming out again.
Aug 21, 2006 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
