Question about Refrigerators
I have a Refg Model FRS24ZRH that leaks from the doors. cannot find where it is coming from.
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 05, 2009
Refg light will not stay on. Unplug refg then plug back in light comes on for a few seconds. Then goes off.
If the lights are leds, then the led driver module is going bad. If the light is a regular light bulb, try tightening the bulb in the socket.
Nov 13, 2016 | Refrigerators
Code f24 comes up on mhwz2600tw00 and I changed user interface , mico computer machine control and door latch. Machine will come on with door open but when I shut door machine will not come on.
I removed back from washer and found wire broke .I also found packet with all codes and wire diagram. Repaired wire and washer works fine. I have had this washer for 2 years and the back has never been removed until this time. I think when washer was assembled wire was pinched and during all the washing in 2 years vibration finally finished breaking wire. All tech. from Maytag can't or want tell you anything about their machines. All they want to do is swap out parts and charge a arm and leg for thei service. You are wasting your time to even call Maytag for tech. support. They don't know anything about codes or anything else. If all applinces go out, refg.,dryer.washer.mico.,range, it want be replaced with another maytag.
Jan 28, 2010 | Maytag Washing Machines
Tring to hook up waterlines to dual valve
Probably to the filter is where the other one goes if you have a filter.
Jun 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool refg. with built-in ice maker model# ED25DQXDW02. Everytime the frig. goes to fill the tray it fills it then over flows some. Is this a problem I can fix myself.
probably have to replace the icemaker take it out and look at the mold and see if you have some teflon coating that has come of and or some water deposit buildup under im on heater on bottom of icemaker. this causes it to let the water drip down on the back of im an causes iceblock in the dispenser bucker. you can order an icemaker 1- 877-262-1479
May 27, 2009 | Freezers
Ice maker leaks with or with out power on the far right side
The water valve (or solenoid) that only lets the water through from the water supply line when the ice maker calls for it is leaking you have to replace it.
May 02, 2009 | Thetford Norcold RV Cooler/Freezer
Inside light on fridge/freezer not working.
OK, the digital logic being out reminds me of the possibility the mother board or circuit board has gone out. If you can get the complete model number on inside of fresh food compartment door frame, near bottom of door, I will be able to help you better. While I wait I will try to look up similar models and get better answers for you. Thanks, Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
