Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Redness in PIcture
I have had my TV for 4yrs and all of a sudden the screen has turned to a red blurr and there is a red vertical line on the left side of the screen. The redness has created red ghost images. If I turn the TV off for awhile it returns to normal, but only last about 5 mins and then it turns red again. What should I do?
  • Anonymous Dec 12, 2007
    Ditto, same issue. Can anyone give suggestions as to cost to fix this?
  • Jersey Joe Mar 08, 2008
    Yes I have the same problem it started last night. Today I tried the convergence menu, could not align the Red + sign to become all white. I even tried reset to Factory default and that didn't work.
I'm very good with electronics and could do the soldering myself but i was wondering, do you have the instructions for the dis-assembly and where on the board the chips are? Also i was told by a local repair guy that i would need some kind of alignment codes. Does anyone know anything about that?
Posted on Jul 01, 2008
  • 934 Answers
This is a failure for the convergence amps.. Replace both STK392-110 amps using STK392-150's instead for greater reliability and then re-converge..
If you're taking this to a shop to have it done it's not that expensive of a repair - but make sure you get your estimate in writing and make sure you relate to the tech that you want the 150's instead of the 110's...
Have a great day!
Bill
Posted on Dec 08, 2007
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Redness in picture
The Convergence amps in this TV set will need to be replaced. This is a typical repair that has to be repaired in almost every tube type projection TV set ever made. Not really a hard job, but a knowledge of printed circuit boards and soldering will be needed and if you do not have the soldering and unsoldering skills, leave the repair to a pro. A repair such as this will run anywhere from 225 up yp 400 bucks. Good Luck and let us know how this repair worked out for you.
Dec 08, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
Picture has red vertical lines, will become
The problem is most likely the panel itself where the ribbon cables are corroded. There is however the also possibility that the tcon connectros need A clean.
May 23, 2010 | Toshiba Regza 47ZV650 47 in. LCD TV
Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
May 13, 2009 | LG 50PX4DR 50 in. Plasma TV
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Sony KP-51HW40
I had the same problem with mine 2 years ago (TV was 1.5 years old at that time) I had extended warranty on TV and it was fixed by Sony at no cost to me. Now yesterday I have another problem with it. All of a sudden screen went BLUE. No Sound either. It could be the CRT (That's what I read here) Out of luck this time. Will call local Repair shop (70 miles away) and see how much it will cost to fix it. Good luck.
May 31, 2007 | Sony KP-51HW40 51" Rear Projection...
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
