Question about Nokia N73 Cellular Phone
Phone is not working properly. it has become slow takes lot of time to open applications
    Sergeant:
    Champion:
  • 212 Answers
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your n73 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the n73 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your phone will now be at its original factory settings.
Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
Posted on Sep 05, 2009
Very Slow....Light Black Screen when opeing
If it has not corrected itself by turning the phone off and taking the battery out for a couple of minutes then turning it back on you should try a factory data reset. In Idle mode, open the application list and select
Settings - Privacy - Factory data reset - Reset phone
-Erase everything.
May 23, 2012 | Samsung S6102 Galaxy Y Duos - Black...
My phone is extremely slow. locking and unlocking the phone takes ages. any function i try to access, even menu or phonebook takes time. recently it had become pretty fast without me doing anything but now...
it may be you have installed a kind of application that takes a lot of CPU usage of your phone.
try to install a kind of task killer application and kill them all.
Apr 29, 2011 | Samsung Star GT-S5233 Cell Phone
My e 63 is getting slow and stuck for last few days after when i installed an application while using net & xplore was open in background please help me now its very slow and take too much time to...
The application is either too big to be easily supported with your phone and its probably taking too much space on your phone,look for a simpler version of the application that you installed in your phone....
I would suggest for you to delete that apllication and free your phone memory....
Dec 17, 2010 | Nokia E63 Cell Phone
I have a nokia n73 and it has become very very slow. I takes a lot of time to open contacts or my dialed called. It takes a lot of time to open anything. Please tell me it's solution. Thanks.
N73 has two types of reset soft and hard reset by performing it most probably the problem will be solved.Soft reset *#7370#.For hard reset you have to follow some steps detailed steps can be found in the link below
http://www.ctek-solutions.co.uk/helpdesk/knowledgebase.php?article=35
Nov 23, 2010 | Nokia N73 Cellular Phone
My blackberry has become very slow all of a sudden.
Applications on the blackberry do not close when opened, each application you open consumes memory. Also the working memory and the memory to store programs are shared unless you have installed a microSD card. Remove and reinsert your battery, if a hard reset speeds the phone up your problem is open applications. If it does not, your problem is that you are out of space and need to remove some applications or install a larger capacity SD card.
Nov 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
My Lg Kp500 was flashed and now it has a network problem?
The mobile is flashed with an old version of upgrade.  or too many applications opened. Keep your screen free of World time also Click on the center button -> click the fwd arrow next to Favourite Apps then click End all. If you close all running apps then the mobile will work faster.
As for network Coverage -> check the firmware version KP500AT_V10b or d would be perfect on network coverage.
Sep 04, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Blackberry Storm the keypad has become very slow to respond.
You don't have a virus. Just make sure that you get the over the air updates whenever available. The latter versions of the phone are much more efficient than the earlier ones. Try closing applications when not in use to speed operation. Press the blackberry button choose switch applications and then close the ones you are not using. You can also delete the default third party software that comes on your phone if you don't need it. For instance, if you never use Verizon navigator, take out a few messengers i.e. aim, yahoo, remove flicker (you can always get this applications back later so no worries).
Jun 30, 2009 | RIM BlackBerry Storm 9530 Smartphone
Lg kg300 speed become very slow
How much extended memory are you using with your handset. The speed issue could be due to higher capacity memory card usage.
And about applications, so let me tell you, applications like Opera Mini are always been slow on LG KG 300.
Apr 05, 2009 | LG KG300 Cellular Phone
System is becoming slow
Open your control panel. Select the performance and maintenance option. 1st run a disk cleanup, after that has finished run the system defragmenter. Once these have completed reboot. Hopefully your problem has been corrected. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Microsoft Windows Xp Home Edition English...
Nokia N73 Cellular Phone Logo
96 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
