Question about Avanti RM4400 Compact Refrigerator
3 way fridge rm4400 not working on 240 volt
Hey can you advise me on what could be the problem as fridge works on gas but not on mains power thanks
  • 40 Answers
Check the fuse, if its not a fuse, then the electric heater under cold plate is bad
Posted on Sep 05, 2009
Where is the heating element for the 12 V side on Rm 2510 3 way Electrolux
two black wires from lower control board to chimney the one marked 12 volt on board
Mar 29, 2018 | Electrolux Refrigerators
We have solar power installed when we purchased the cvan only the lights work stove and fridge only run on gas
it will be necessary to check the total output of the panels as the inverter may not be able to supply the current required to run the stove and fridge off the panels
Because of the high power required for the stove , it would only be gas and the fridge will be 3 way--- 12 volts , 240 volts and gas
Solar panels are normally there to recharge the batteries and run lights
Feb 13, 2018 | Kitchen Ranges
Today i found my thetford fridge in c/van not working on 240 power so i turned it on to gas and it workes. Any idea what might be the problem?
the fridge works by heating crystals that creates a gas that is the refrigeration
if it works on gas then the system is good and indicates that the 240 volt heating element is not working
find a caravan repair center and have it checked out
Nov 25, 2016 | Thetford Refrigerators
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
Electrolux siegen ghbh 3 way fridge model rh275 stopped working on gas but works on 240 volt
check that some bugger hasn"t turned your taps off or gas bottle -otherwise call a camper trailer dealer and ask the the best advice on what to do -might just be a blocked gas jet -but you will need a licensed gas fitter to check it for you -wont cost too much
Aug 07, 2014 | Electrolux Refrigerators
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Fridge/freezer in a motorhome has stopped working on gas any help & advice would be greatly appreciated.
I am guessing this is a "three way fridge" 12 volt, 240 volt and lpg gas.
This is an absorbtion refrigerator and it uses heat to drive the cycle.
The things to do are;
Clean the gas jet, Piezio starter and thermocouple.
Also clean the rust, carbon and scale away from the heater tube and chimney.
Hopefully all will be good again
May 02, 2011 | Refrigerators
My fridge will only work on 220 volts but not on 12v or gas anymore. the fridge worked perfectly then the gas stopped working one day, i discovered that the gas pipped was blocked, after unblocking it the...
Your refrigerator has a freon that we call R-717 which is amonia. You have to heat the amonia to have refrigeration. using the 12 volt side will cause power drain on batteries. If you had to close the gas valve most of the way down this is telling me that he gas pressure regulator went bad. The 220 volt heater is still working that is why this is working. change the regulator and you should go back to gas for operation. If the helps give me a rating please. thank you.
Apr 08, 2011 | Refrigerators
Avanti RM4400 Compact Refrigerator Logo
218 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
