Question about Toshiba 65HM167 65" Projection Television
How do you reset the lamp timer on a toshiba tv that the part number is a 65hm167
  • MICHAEL May 09, 2012
    I replaced bulb in my 65HM167 and still had no picture,called the customer service center and went through a long process of reseting the tv which didnt help,In the end i just simply took out the bulb tapped on it a few times put it back and TV worked fine .Back when we first bought the Tv the same thing happened and someone from Toshiba told us to do this and it worked then also.Give this a try before you spend a bunch of money and time on the phone trouble shooting .
SOURCE: projection lamp timer reset
Turn your television on
Press volume down on the TV
Press the mute button on the remote
Green LED light on power button will flash
-timer now reset (no more warning light)
Posted on Jun 10, 2008
SOURCE: Yellow blinking light on Toshiba 65HM167
Guest...you are not going to have any luck! If you can believe this our TV is STILL broken. And it has been since July 7th!!!! I have been fighting with Toshiba I have reported them to bbb and also to the federal trade commission. I have faxed the work order from the first time someone came out to look at it, a copy of my cell phone bill to prove the first time I called was really way back in July!! It is a main board in the tv and they keep telling me it is on "extensive backorder" Finally they offered us 3 options...a refurbished 65in, a brand new 52in LCD or a full refund in 6 weeks!! I will NEVER buy a Toshiba anything again. I suggest you call this number 1 800 351 5481. When someone picks up tell them you need to talk to Toshiba in regards to a TV, they will transfer you directly to them. The sooner you start a file with them the better because as you can see when I posted this and yes it is still broken. I have also faxed copies of everything we have been dealing with to the offices of Phillip Schoonover who is the CEO of circuit city where we bought the TV and also Atsutoshi Nishida the CEO of Toshiba. You should just ask to talk to Evette....she is the customer service supervisor who I have been dealing with. If there is anything else I can help you with please let me know....trust me I have ALL the information you will need.
Posted on Sep 21, 2008
SOURCE: How do I reset lamp timer on Mitsubishi DLP TV?
I cant find the solution to reset my lamp hours, I replaced it, unplugged the tv like i was supposed to to. Its not reset. I have a 73" 1080p ...wd 73831 series
Posted on Aug 23, 2009
  • 668 Answers
SOURCE: reset timer toshiba 62hm116
I do not think failing to reset the Lamp Timer would cause the Lamp not to light. You need to get into the Factory Menu while the picture is on in order reset the Timer. I believe you have a Ballast issue either because the Power Supply is not powering the Ballast or the Ballast not Powering the Lamp. In either case, the only way to know is to have a professional to check it out and give a estimate for repair.
I hope this helps,
Skyassoc
Posted on Aug 29, 2009
vinnyq
  • 157 Answers
SOURCE: toshiba 65hm167 black screen with video input
That is correct, if the lamp was bad then you will not see a picture at all. The fact that you are getting menu means the lamp is good and most likely the processor and light engine are also okay. Check other inputs to see if you have the same problem on all the inputs.
Posted on Nov 11, 2009
Replaced lamp and i still have a yellow light and no picture
Check that your lamp fan is working. It may also be a bad ballast for the lamp.
Mar 08, 2012 | Toshiba 65HM167 65" Projection Television
How due you replace the lamp in the Toshiba Toshiba 65HM167 65 in. Television
Pop off the front panel below the tv screen. Remove bulb cover door (screw) and then remove the bulb housing. Replace with new bulb and reverse the process.
Thank you and best of luck!
Jun 06, 2011 | Toshiba 65HM167 65" Projection Television
I just replaced the lamp in my TV and now it will not turn on. Is there a reset or something? Why wont the TV turn on. The replacement procedure is rather simple and I'm sure I did it properly.
hello just checked the manual it said if the lamp door is not fitted securely the tv will not turn on also make sure the lamp is fitted securely aswell good luck
regards
shaun
May 25, 2010 | Toshiba 65HM167 65" Projection Television
My Toshiba Model no. 65HM167 does not power up. The lamp light on front of t.v. flashes and thats about it. I replaced the lamp but still no go. Help.
CK the Lamp Fan if it stops running Lamp will not light and if thats ok Ballast Board it is what turns Lamp on!
Visit Encompass Parts Distrubtion for Parts List and numbers 1-800-638-3328
Mar 23, 2010 | Toshiba 65HM167 65" Projection Television
How do I reset the DLP lamp timer on my Toshiba 44NHM84 TV?
Hi,One way to reset lamp timer is to unplug tv wait 5 min and plug it back again.
Jan 05, 2010 | Toshiba 65HM167 65" Projection Television
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Toshiba 65hm167 black screen with video input
Nov 02, 2009 | Toshiba 65HM167 65" Projection Television
Toshiba 65HM167 65" Projection Television Logo
373 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
