Question about Canon Photography
Canon elph 2 film door wont open , tried to open with door release button but wont budge.
    Habit-Forming:
  • 80 Answers
You need the camera powered up and all the film used to activate the release mechanism for the lock to release the film door, the Elph film door will not open until all the pictures have been taken. It uses A CR2 Lithium battery
Posted on Apr 01, 2013
  • 125 Answers
SOURCE: Canon FTb 1974
I used to use a Canon older than yours. So I'm guessing it might have the same construction. The film advance knob may have a small holding pin or it is just out of it's correct position. If you can feel the knob and see if you can hook the pin back on then your problem is partially solved. If that doesn't work a techncian would probably dismantle the camera from the top as well as from the hinge. It can be fixed but I'm not sure if the fixing will be cheap. I'm a handyman of sort so I would try to unhinge the pin (other side of the knob) and use a flashlight and a long thin wire to see if I can unclip the side that is hooked to the knob. Either way, this is not going to be easy and you need to be careful not to scratch(at least minimize) the inside of the camera or damage any part of the shutter. This is almost like a doctor doing brain surgergy so if you don't have a steady hand and even temper don't try it. It's not going to be easy. Usually the back cover has the hook and the advance knob has the flat metal sheet that holds on to the cover's hook. If you can pull this metal sheet up, that should release the back cover. You'd have to use a strong wire or paper clip. Not the copper types but the stainless steel ones and use a long nose plier to create a hook.
Posted on Jul 18, 2008
SOURCE: Cannon ELPH LT
The ELPH LT takes APS film, like the Kodak Advantix.
Posted on May 18, 2009
SOURCE: canon t50 wont load film
Take the film a little further almost inside the chamber and close the door, it's probably automatic rewinder can't find your film.
Posted on Jul 24, 2009
  • 12 Answers
SOURCE: the button for the door wont release the door.
Rewind the film first. If the door is still locked, then procede with a plan outlined on page 121 of your camera manual(lever on the right side of the camera)here is a digital copy of it. http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Posted on Nov 12, 2009
fikretunalir
  • 238 Answers
SOURCE: Anyone know where I can access a user manual for a
This is Canan Elph2/ İxus II User Manual.
If this helpful please vote with higher rank. Thank you.
Posted on Feb 25, 2010
We have a Canon A1 that hasn't been used in years. We loaded it and used it a few times yesterday, but now it wont' advance the film, it's stuck. Ideas?
Could it be that it thinks it needs to have the trigger pressed?
The film will not advance past an unexposed frame.
The other possible is that the end of the film has been reached.
Try pressing the release button and rewinding the film.
If you have a dark room available you can always resort to opening the camera.
Excellent camera. Have had one for many years back when film existed.
Mar 02, 2016 | Canon A-1 Manual Focus 35mm Film Slr...
Film release button on bottom of body is stuck in. Wont pop back out.
If you can not wind and release the shutter, the film release button will not come up.
If you can not trip the shutter, by replacing the mirror release magnet at the bottom will usually fix the problem.
May 22, 2010 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Setting date on Canon elph Jr.
To set the date:
1. Press the Date button (rear left button on top of the camera)
2. Press the Select button (small round button up and to right of date button, may need pen point to press), display may show 97 1 1, with the 97 blinking.
3. Press the Set button (below the Select button) to change the value of the blinking character.
4. Press the Select button again to change to the next character. Use Set again to change. Repeat until date is set.
5. Press the Select button when all characters are set.
To set time, press the Date button again and the display should change to time (24 hour mode). Use the Select and Set buttons as above to set the correct time.
C, H, and P indicate the type of picture you want to take. C stands for Classic, and the picture will be in a standard aspect ratio. H is the wide angle setting, and the printed picture will be printed wide angle. P is panoramic, and the printed picture will be even wider angle than H. All this depends on the processor who develops your pictures for you. Ask if their equipment can read and process according to the instructions your camera will automatically put on each exposure on your film.
The three buttons on the left side are:
Top -- Flash setting. On (lightning bolt) or Off (lightning bolt with line through it).
Middle -- Film rewind button. Film should rewind automatically when fully exposed, but you can rewind before the film is fully exposed by using this button.
Bottom -- Self timer. Pressing this button puts a clock symbol on the display. When this is set, the shutter will delay 10 seconds after the shutter button is pressed. Press this button a second time to turn off the self timer.
Mar 17, 2009 | Canon Elph Jr. APS Point and Shoot Camera
Cannon ELPH LT
Mar 08, 2009 | Canon Elph LT 260 APS Point and Shoot...
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
Camera wont accept any film?
1.The film leader should be placed correctly.
2. the ASA detecting pins in the film champers should be clean.
3. Check for any buttons being in pressed conditions.
4.See whether the frame counter resets when opening the door
5.Then try with a mechanic.
Mar 26, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
AE-1 Didn't Take Pics
Possibly the film did not go through the camera. If it did, the problem may be the 2nd(or closing)curtain magnet on the bottom of the camera. When the magnet is working the closing curtain of the shutter is held back 1 to 1000 miliseconds-depending on the shutter speed selected by you. 1ms=1/1000 sec. 1000ms=1 sec. You can tell by 1. removing the lens 2.setting the shutter speed to the "B" setting 3. opening the film door and looking through the camera 4. releasing or firing the camera and keeping pressure on the release button. If the magnet is working, the shutter will stay open as long as the release button is kept pressed down. The closing curtain will close as soon as the release button is released. When the magnet fails, both curtains travel across the film plane together and no exposure is made. Sometimes there is corrosion on the magnet where the wires connect. Sometimes there is some foreign substance or object that interferes with the face of the metal unit that attaches to the magnet when the camera is wound. Sometimes the magnet just fails and needs to be replaced. If the magnet checks out OK the problem may be in the circuits that control the release of the magnet. If this is the problem, the camera needs to be looked at by a competent repair shop. Just so you know, new parts are getting hard to come by, but there are tons of used cameras around that parts can taken from. Hope this helps.
Jun 24, 2007 | Canon EOS-AE-1 35mm SLR Camera
Photography Logo
460 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
