Question about Dryers
All the lights on front panel on my frigidaire FEQBB30DS0 dryer
All the lights on the front panel on my FEQBB30DS0 start flashing on the front panel, when the dryer isn't in use.
Once this starts, you can't set anything, but if you start the dryer, it runs with the setting that was flashing at the time you push start.
Kinda like a dryer settings slot machine
If it is unplugged for a few minutes it goes to normal for 1 use, but not always.
  • 135 Answers
Sounds like one of the buttons is stuck. You may have to replace the touch keys panel
Posted on Sep 05, 2009
Frigidaire front load dryer not drying all panel lights flashing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Frigidaire Dryers
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
Aug 16, 2014 | Frigidaire AEQ7000EG Affinity Series...
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
WHY IS DRYER TURNING OFF AND 4 LIGHTS ON PANEL FLASH
Good Morning Friend,
I understand your Frigidaire dryer, model# FEQ1442ES, runs for about 10 minutes then turns off. I also see, that when it turns off, all the lights on the front panel are flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer LEQ2152EOS
This is indicating an open door circuit. Since the circuit cannot complete, you cannot program any cycles and the "clean filter" light will remain on until you can do so. You will find a technical data sheet inside your dryer, either just under the top panel, or inside the lower panel, if so equipped. It will explain how to test the control board and the door lock assembly.
Sep 03, 2012 | Frigidaire Dryers
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Dryer goes off after ten minutes an=d the bank of lights
check thermistor on outlet side of blower. if its worn thru plastic to sensor then its bad. this causes several control board issues. remove top then front panel to access this at bottom front.
Jul 05, 2009 | Frigidaire GLEQ2152ES Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Dryers Logo
177 people viewed this question
Top Dryers Experts
