Question about Maytag Performa PAV2200
My washer doesn't wring the clothes fully.
My Maytag Performa washer doesn't wring the clothes well enough, the towels are still dripping wet,it seems it doesn't spin fast enough.What can be the cause and the solution?.Thank you from Toronto.
  • 4,070 Answers
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Posted on Sep 05, 2009
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: My Maytag Performa PAV2300AWW washer doesn't wring
Sears has the part you need:
pd_26_464_12002213?$pddetailsth$ #24 on diagram Thrust bearing kit (series 10) Number:12500036Substitution:12002213 $31.28 In stock Quantity Add To Cart To be sure you have the correct one your serial number should start with 10. One thing to remember when installing the new kit (which comes with extra washers) If you have too many washers then the tub will not lock down for wash mode and the clothes will get all knotted up. If you have too few washers then the brake will not release and the drum will not spin. So make a note of just how many was on the old unit AND the order they came off.
  • 135 Answers
You may have a restricted pump that is not pumping all the water out. That will slow the spin down also.
Clothes are not wringing out
Washing Machine Won't Wring Out Clothes Properly - DIY ...
www.diychatroom.com/.../washing-machine-wont-wring-out-clothes-pro...
Apr 16, 2013 - 6 posts - ‎4 authors ... thing - the spin cycle doesn't really seem to do an effective job of wringing out theclothes once. ... Sounds like it's not spinning fast enough.
Washer does not wring out the clothes. Clothes are dripping ...
Nov 23, 2015 | Washing Machines
Have a quiet pak4 kenmore elite. the spin cycle seems to not wring out the clothes well. In some cases, the items are dripping wet. I tried running an empty cycle, (rinse and spin setting), and it seem to...
Try this: remove the front lower acces panel(below the door going acroos the lower portion of the washer)
by removeing the attaching screws and pull off, then inside you will see a cylinder shaped unit with a cap with a twist handle on it,this is the filter pump, unscrew the cap to remove the trap and clean out completely, there will be some water in it when you open it so have a towel ready to sop up the water,reassemble everything and try a load of clothes, this will fix your problem. Good luck !
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
My Maytag Performa PAV2300AWW washer doesn't wring the clothes well enough, the towels are still dripping wet,it seems it doesn't spin fast enough. What can be the cause and the solution?. Thank you from...
Sep 05, 2009 | Maytag Performa PAV2200
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Washing Machines Logo
868 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
