Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb drive keeps disconnecting and reconnecting. When reconnects the pop up box for action to be performed( open files etc) in Xp professional keeps coming up
    Problem Solver:
  • 12 Answers
Try in another usb ports. Then try in other computers. loose connections. If problem persists replace the usb drive.
Posted on Sep 05, 2009
  • Jeremy11274 Jan 05, 2011
    I had the same problem and I solved it by connecting an external POWERED usb hub to my computer! You can just connect your drive to the usb hub and it should work again.
    (If you have a laptop you should first try to change the USB settings in the power-saving-options. Sometimes windows shuts off the power of the USB ports on laptops to save energy)
Had the RSQ HD 787 for almost a year and now i am having problems. Need help. Can you help me?
Try this:
1. Login as an administrator and open "Device Manager"
2. Click on View and select "Show Hidden Devices"
3. Open "Disk Drives"
4. Delete any device that is grayed out
5. Disconnect your usb cable and reboot your laptop
6. When Windows is fully loaded reconnect your usb cable
Hope that does it for you.
May 16, 2014 | RSQ HD-787 HDD Multi-Format Karaoke Player...
I am getting an "error 5200" on my Canon i900d printer, and it just doesn't print anything. This seems to come and go. I have turned off and on as it says and nothing helps. What is wrong?
Please perform the steps below and check..
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
now perform these steps
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
now check if the error is still present.
May 20, 2010 | Canon I900D InkJet Photo Printer
Hello, I'd like to know why my Dynex Wireless N usb adapter keeps disconnecting from my laptop, to reconnect I have to unplug / plug back to get signal, then I get signal for a short period of time then...
Try turning off Wireless Zero Configuration,in services. & disable on startup. Start>>Run>>services.msc navigate down till you find it, double click & change.
Feb 10, 2010 | Dynex Enhanced Wireless-G USB 2.0 Network...
Western Digital external USB 2.0 Problem
Buy an External USB 2.0 Hub with the 5.0V power supply. I have a TARGUS 4 Port Hub. MY WD2500XMSB works fine thru the HUB, but will not work using any cable (even the one that came with it) when directly connected to the USB port on my computer. The power consumption of passports sometimes exceeds the .5 milliwat rating for the ports and ccause the port power to interrupt (see USB 2.0 specifications). The external hubs with external power have a higher power output usually an can power the passport drives. CW Rumsey
Oct 07, 2009 | Western Digital 250GB MyBook External USB...
Sony Walkman NWZ-E438F connects & disconnects itself from USB
I suggest that you uninstall and reinstall the USB Driver to resolve the issue.
Follow these steps to uninstall the driver and confirm the player is recognized properly.
IMPORTANT:
  • This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  • If you are using the Windows® XP operating system, you must have Service Pack 2 or later installed.
  1. Click Start and then click Control Panel .
  2. In the Control Panel window, click Performance and Maintenance .
  3. In the Performance and Maintenance window, click System .
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, under Device Manager , click the Device Manager button.
  6. In the Device Manager window, click the plus (+) sign in front of Disk drives .
  7. Click to select the Sony USB device .
  8. From the menu, click Action and then click Uninstall .
  9. In the Confirm Device Removal box, click OK .
  10. Disconnect the portable player from the computer.
  11. In the System Settings Change box, click Yes.
After that, restart the computer and reconnect the Player to resolve the issue. USB Drivers are generic to the Operating System and will reinstall automatically after restarting the computer. I hope it works.
Sep 22, 2009 | Sony Walkman NWZ-A826 Digital Media Player
What is the model of your computer? Are you connecting the Flash Device in the front or back? Are there any special softwares running in the background?
Ryan Frame
Creative Energy Associates Technical Center
Sep 04, 2009 | Electronics - Others
Problem regarding my laptop
Do you mean after you put in a CD/DVD they are not starting up/loading?
For Windows XP:
You can open up My Computer, Right Click the CD/DVD Drive and choose Properties. Click the Autoplay Tab at the top of the box that opens up and see what option is selected.
You will see a drop down menu box that you can choose the different types of Autoplay features: Music Files, Pictures, Video Files, etc.
Under Actions, is Select an Option to perform selected and is Take No Action the option selected? Below that box is the option to "Prompt me each time to choose an Action" selected?
You can go to each category and set your preferences to tell your computer what action to take for each type of media you put in the CD/DVD Drive
Jan 27, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Doing siytem restore,and have no operating system.Vista home premium model no s 3460 sofware build 82APv3PrA1.Im under warranty what can i do?.In the start of system restore computer stopped,message reeds...
Starting the recovery from power up If Windows Vista cannot open and if the Recovery partition on the hard disk drive is functioning properly, you can perform a System Recovery by performing the following procedure:
  1. Turn off the computer.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. Turn on the computer.
  4. Do one of the following actions depending on how Windows Vista was installed:
    • If Windows Vista came pre-installed on your computer, press the F11 key repeatedly when the first screen opens (the logo screen), until Recovery Manager program opens on the screen.
    • If your computer was upgraded from Windows XP to Windows Vista, press the F10 key repeatedly when the first screen opens (the logo screen) until Recovery Manager program opens on the screen.
    If Recovery Manager does not open, a set of recovery discs is needed to perform a System Recovery. Follow the instructions listed in Starting the recovery from recovery discs .
  5. Click Next .
  6. On the screen that prompts for Microsoft System Restore select No , and then click Next .
  7. The Recovery Manager gives you the option of backing up your data files. Backing up your files is recommended. To back up your files select Yes , and then click Next . Follow the onscreen instructions. If you do not want to backup your files, select No , and then click Next .
  8. After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes the setup. Then, turn off the computer, reconnect all peripheral devices, and turn on the computer.
  9. Before using the computer, update and protect it by reinstalling any virus and security software that was installed before the System Recovery.
  10. Reinstall any software applications that were added after puchasing the computer, and replace any files that were backed up.
Nov 06, 2008 | HP Computers & Internet
Media Full, Shutting Down
Have you contacted Memorex?
Feb 02, 2008 | Memorex MMP8567 MP3 Player
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
3,024 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
